I bought a Aeon Labs HEM Gen5 to replace my 2nd generation which would constantly throw firmware messages in the logger and occasionally one of the amp legs would stop reporting. I would have to remove and re-add the device to get it back. I hope this new one solves that, but I had some issues getting it up and running. I tried to add it securely and it would just give errors. I then move it closer to the Z-NET since I saw that others had issues when it was further away. After I got it within inches of the Z-NET, some of the errors stopped, but I still had a few, and it wouldn't create the 8 child nodes required. Only after I added it non-securely did everything add successfully. Now, this isn't a big deal for a power meter, but I don't like the fact that it wouldn't add under the secure mode. Here's an excerpt from the logger:
Jan-21 12:13:19 PM Z-Wave Warning The device at node 53 should result in 2 child devices being created, but the node interrogation currently has 0. This may still result in a successful child creation.
Jan-21 12:13:19 PM Z-Wave Warning An error (B) was reported attempting to get multi-channel or multi-instance information from node 53
Jan-21 12:13:06 PM Z-Wave Node 53 is a Z-Wave Plus node. Retrieving ZWPlus Info...
Jan-21 12:13:06 PM Z-Wave Node 53 is Z-Wave version: Lib: 3.92 App: 1.31
Jan-21 12:13:05 PM Z-Wave Node: 53 Controls Class(es): DEVICE_RESET_LOCALLY
Jan-21 12:13:05 PM Z-Wave Node: 53 Supports Secure Class(es): VERSION_V2, MANUFACTURER_SPECIFIC_V2, METER_V3, CRC_16_ENCAP, MULTI_CHANNEL_V3, CONFIGURATION_V4, ASSOCIATION_GRP_INFO_V2, ASSOCIATION_V2, FIRMWARE_UPDATE_MD_V2, POWERLEVEL, DEVICE_RESET_LOCALLY
Jan-21 12:13:05 PM Z-Wave Node: 53 Supports Class(es): ZWAVEPLUS_INFO, VERSION_V2, MANUFACTURER_SPECIFIC_V2, METER_V3, CRC_16_ENCAP, MULTI_CHANNEL_V3, CONFIGURATION_V4, ASSOCIATION_GRP_INFO_V2, ASSOCIATION_V2, FIRMWARE_UPDATE_MD_V2, POWERLEVEL, SECURITY
Jan-21 12:13:05 PM Z-Wave Z-Wave manufacturer information for node 53, ID: 134=86H (Aeon Labs), Type: 258=102H, ID: 95=5FH
Jan-21 12:13:04 PM Z-Wave Received information on 11 secure command classes from node 53
Jan-21 12:13:03 PM Z-Wave Getting SECURITY class information for node 53
Jan-21 12:13:03 PM Z-Wave Z-Wave Security Scheme and Key Exchange was successful for node 53, now waiting for the device to finish storing information before proceeding...
Jan-21 12:13:03 PM Z-Wave Security device (Node 53) is verified as operating securely in this network.
Jan-21 12:13:03 PM Z-Wave Negotiating or Verifying SECURITY SCHEME for node 53
Jan-21 12:13:03 PM Z-Wave Synchronize nodes finished. Number of device nodes to be created/added = 1
Jan-21 12:13:02 PM Z-Wave Main Z-NET: Controller firmware version: 4.32
Jan-21 12:13:02 PM Z-Wave Main Z-NET: Controller Manufacturer: Express Controls, ID=0x2, Type=0x5
Jan-21 12:13:01 PM Z-Wave Done. Node 53 Added.
