Trying to help some friends set up simple home automation and more complex whole-house audio. I think the Soundbridge along with HS and your plug-in may work. I still am confused, after looking at both the Soundbridge and the plug-in documentation.
1. What is the musics server of choice when using HS?
2. With the current version, can I accomplish with the plug-in all the functions as though I were in front of the Soundbridge, remote in hand?
3. Is the building of playlist, adding music (i.e. library management) accomplished through the Soundbridge and/or the Web interface?
The house is very large, with two separate home theater setups and speakers in other areas (at least 4 other "zones") home-run to a utility closet. One goal is to have the same music playing throughout the house (party mode).
4. It appears that your plug-in allows either a single Soundbridge to be address or all units to recieve the same command - correct?
A long term goal is for my friends to say "Play some jazz on the patio" and have it happen. I also want to add IR control through HS and start with some simple lighting control. All good reasons to incorporate HS.
5. Could you talk about - or perhaps others will - how they are using the Soundbridge in a whole-house audio setup?
Barry
Barry
