Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer UPB Plug-In (Beta)
HomeSeer UPB Plug-In (Beta) Discussion area for HomeSeer's UPB Plug-In
Old April 23rd, 2011, 06:06 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
'Set to off' Trigger - How does it work?
I want to trigger an event when I press the Off side of the rocker on a UPB wall switch. If I use 'Change to off' it works only if the switch changes from On to Off, but I want it to trigger whenever the Off side of the rocker is pressed.
I tried 'Set to off', and that does work whenever the Off side is pressed - but it also triggers if the switch is Off and I turn it On. I've tried it with two (PCS) switches, and it works the same on both of them.
I am now using a link, and that works fine, but I'd still like to know how the 'Set to ___' trigger is supposed to work. Is this a problem with my installation? Is it a bug? Is it unique to the UPB plug-in?
If this is how it is intended to work, under what conditions would you use this trigger?
HS3 Pro Edition 3.0.0.435
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old April 23rd, 2011, 11:05 PM
drozwood90 drozwood90 is offline
Curious, sounds like status update is not set on your switch.
Esp. since you said the link is working, but the device is not. I THINK that links are sent all the time (if they are associated to a switch's action).
In upstart, do you have the switch set for update status...? Also, what kind of switches are you using? I've got 2-40's and the 'update status' action should be checked (I've not been in upstart for a while). I can trigger from links or devices.
--Dan
Old April 24th, 2011, 09:27 AM
My switches are all PCS WS1D.
I haven't been in Upstart for a while either, but I'm reasonably sure the switches are set to update status because HS tracks their state reliably.
I can trigger from both links and devices. The link trigger* and 'Change to' trigger work as expected, but the 'Set to off' trigger just seems to act non-intuitively. (I haven't tried 'Set to on'. I'll have to try that one of these rainy days.)
Maybe it's the PCS switch?
____
* Although the event with the link trigger works without any trouble, it continues to display a Last run date of 'Unknown'. Another minor mystery.
Old April 24th, 2011, 10:54 AM
nightwalker nightwalker is offline
As much as I'd like to make sense of this as well as you guys would, I can't either. I suspect there is a slight incompatibility between the way HomeSeer works and UPB switches work and how the plug-in translates all of that. Pressing a rocker switch that is already off does nothing to change it's status including changing the date of that off in HomeSeer. I wouldn't expect that HomeSeer would respond to a "change to", since no change was detected from a HomeSeer device status prospective.
As Uncle Michael has discovered you can work around this, sort of, using links, however links also act a bit odd in the translation of actions from the switch to HomeSeer in the plug-in. I have a few links that give an error message in HomeSeer even though the switch behaves as I want and works properly, just not according to HomeSeer.
I guess like the rest of us I've learned to make adjustments to my system to get around these deficiencies. I have logged the errors I get and forwarded the logs and observations to Omen who I assume is still working on the plug-in since it's still in a beta state.
Marty
Old April 24th, 2011, 11:47 AM
Marty,
Thanks for your insight. Although I've been using UPB for a while now, it's my growth path from X10, not my primary technology, so my experience is limited to the basics. I see some applications starting to crop up, though, so I'm trying to educate myself on the finer points.
I agree, the 'Change to' trigger is not going to do what I want. That's why I was exploring the 'Set to' trigger.
I think what I'm looking for is the UPB equivalent of 'Received X10'. It's probably a Quixotic search. Doesn't exist. Not going to happen.
Old April 24th, 2011, 12:16 PM
Anyone having been here for more than couple of years has transitioned from X10 to something else, once or many times. Since I don't see the HomeSeer devices change at all if the status does not change I don't see it ever working unless something is done within the UPB plug-in that forces that change on a HomeSeer device.
The change to UPB is close enough to have lead us all down the path, that they are far more similar than they really are. I have a feeling that developers are also lead down that same path as I've not seen anything yet that takes full advantage of UPB capabilities without a few work arounds.
I have a feeling that the closest you're going to get to a received x10 is using a link, even though it's not an exact match.
Old April 24th, 2011, 01:15 PM
I agree. As soon as I put it into words I realized the path I was on.
If only things would get better, but without changing anything!
HTML code is On
