Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer UPB Plug-In (Beta)
HomeSeer UPB Plug-In (Beta) Discussion area for HomeSeer's UPB Plug-In
Old December 2nd, 2015, 05:45 PM
Ricky Ricky is offline
PulseWorx PGW Gateway
I would like to upgrade my powerline interface module (PIM) to the PulseWorx Gateway PGW which uses Ethernet. Currently using a com based PIM. I noticed in the plug-in (version 3.0.0.2) that there isn't a choice in the powerline device menu for the PGW. Is this in the works or is there another way to interface with the PGW?
Also I noticed that in the new (ver 8 build 41) UPStart you can export to the PIM directly. Is that something new and will I still export to the homeseer.upe file?
Old December 2nd, 2015, 10:01 PM
Uncle Michael's Avatar
Uncle Michael Uncle Michael is offline
It is my impression that HST does not plan to add capability to this plug-in, or if they do, it will be quite low in priority. If you are using HS3, I think Spud's UPB plug-in is the most likely (only?) alternative where new capability could be added.
HS3 Pro Edition 3.0.0.435
HW: Stargate | NX8e | CAV6.6 | Squeezebox | PCS | WGL 800RF, Rain8Net+ | RFXCOM | QSE100D | Vantage Pro | Green-Eye | X10:
Compose, XTB-232, -IIR | Edgeport/8 | Way2Call | Ecobee3
Old December 2nd, 2015, 10:43 PM
Yes, I am using HS3 Pro.
I wonder how they can choose to ignore UPB?
HTML code is On
SMS Gateway for HS3 beerygaz SMS Gateway (3P) 98 August 11th, 2016 12:50 AM
Looking to replace Zwave CA3750 w/PCS PulseWorx UPB Output Control Module & HomeSeer? rayvino UPB plugin by Spud (3P) 17 February 4th, 2015 08:27 AM
Looking for IR >> UPB gateway rsisson Lighting & Primary Technology Discussion 15 July 31st, 2012 10:53 PM
Pulseworx KPLD6 Controllers jdklem HomeSeer UPB Plug-In (Beta) 6 October 30th, 2011 03:09 PM
Pulseworx upb pim-r on quatech qse-100d sphiend Lighting & Primary Technology Discussion 0 November 18th, 2010 04:19 AM
