Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer UPB Plug-In (Beta)
HomeSeer UPB Plug-In (Beta) Discussion area for HomeSeer's UPB Plug-In
Old October 3rd, 2016, 04:47 PM
cjrs27's Avatar
cjrs27 cjrs27 is offline
Seer Plus
UPB Plugin for HS2
Added four new Simply Automated "US1-40 Single Rocker Dimming Switch - Timer" to UPB Upstart (Version 8.0 Build 56)
Can control the new switches from Upstart
When I start HS2, this appears in the log:
10/3/2016 1:59:04 PM - UPB - ** Retry count exceeded, UPB Message transmission failed.
10/3/2016 1:59:04 PM - UPB - UPB Command transmit failure. Setting units related to UPB module ID 249 to unknown/failed state
10/3/2016 1:59:16 PM - UPB - ** Retry count exceeded, UPB Message transmission failed.
10/3/2016 1:59:16 PM - UPB - UPB Command transmit failure. Setting units related to UPB module ID 248 to unknown/failed state
10/3/2016 1:59:20 PM - UPB - ** Retry count exceeded, UPB Message transmission failed.
10/3/2016 1:59:20 PM - UPB - UPB Command transmit failure. Setting units related to UPB module ID 41 to unknown/failed state
10/3/2016 1:59:25 PM - UPB - ** Retry count exceeded, UPB Message transmission failed.
10/3/2016 1:59:25 PM - UPB - UPB Command transmit failure. Setting units related to UPB module ID 206 to unknown/failed state
None of the new switches are listed in HS2.
Ideas or recommendations welcome.
Best Regards, Bob
Old October 6th, 2016, 12:50 PM
cjrs27's Avatar
Seer Plus
Discussions on another board got me thinking more and I decided to just start over.
- I deleted the new switches and all of their links and scenes from Upstart.
- Added them back in to Upstart, one at a time and added a "ctrl link" for each newly added switch.
- Manually forced the export from Upstart.
- Started HS2, deactivated the UPB module and then activated the UPB module.
Now, all of the new switches are listed and under the control of HS2. I do not know why that worked, but it did.
HTML code is On
Is RCS TR40 RS-485 Supported using HS3 RCS Serial Plugin - Plugin now working! dzee HomeSeer RCS Serial Thermostat Plug-in 117 August 5th, 2016 10:39 AM
Does this plugin work with the Windows Media Center plugin? rdimitri SqueezeBox Plug-In (3P) 0 May 16th, 2011 05:05 PM
Upgrade procedure for ACRF plugin from W800 free plugin htsource ACRF Processor (3P) 14 January 26th, 2006 11:21 AM
Switch-to messages, plugin restart, and plugin startup Michael McSharry Plug-In Development 4 January 27th, 2003 11:20 PM
