Go Back   HomeSeer Message Board > Lighting & Primary Technology Plug-ins > Lighting & Primary Technology Discussion > HomeSeer Insteon Plug-in
HomeSeer Insteon Plug-in Discussions related to HomeSeer's own Insteon Plug-in
Old May 23rd, 2017, 10:35 PM
Isk82 Isk82 is offline
Seer Plus
EZIO8 support?
Was there ever support or a plug-in for this device: the Smartenit EZIO8SA. I am asking here because I figured if anyone did it would be Marc Sanders. Thanks for a reply
Old May 24th, 2017, 05:20 AM
mnsandler's Avatar
Insteon Overlord
the device is supported in the Mark Sandler Insteon plugin. The HS Insteon plugin does not support this device
Mark
HS3 Pro 3.0.0.368
Hardware: Insteon Serial PLM | Vista Alarm 20P with AD2USB | HAI Omnistat2 | 1-Wire HA7E | RFXrec433 | Dahua Cameras | LiftMaster Internet Gateway
Plugins: Insteon (mine) | Vista Alarm (mine) | Omnistat 3 (by Kirby) | Ultra1Wire3 | RFXCOM | NetCAM | MyQ | BLRadar | BLDenon | Jon00 Charting
Old May 24th, 2017, 08:18 AM
Seer Plus
Mark, I am using your plug-in with HS 2. Does that version support it? And if so, help. Because I see the PLM as a light switch with on and off. If there's a way to address the 8 relays, I don't see it.
Old May 24th, 2017, 10:41 AM
mnsandler's Avatar
Insteon Overlord
i'm not supporting hs2 anymore. there was a third-party hs2 plugin that supported the ezio devices but you won't be able to get a new license for it
HTML code is On
Missing support for Fibaro and Qubino relays and very poor customer support response mikee123 HomeSeer General Discussion Area 33 June 27th, 2016 05:20 AM
Hub Pro support DanITman Insteon Plug-in (Mark Sandler) 3 January 7th, 2015 03:51 PM
HA Controller Zwave support/Omni IR Support. KLS General Home Automation Hardware Discussion 0 May 25th, 2006 10:26 PM
