I'm not sure if this is a BLDSC plug-in issue or (more likely) I still haven't understood how events work with HS3.
I am trying to program a series of events that occur if we are away from the house to make it look as though someone's home. As you can see below, I first test for time (with security turned on at +/- 9 minutes) and then if the DSC is in "Away" mode then I would expect the events to occur.
But nothing happens! The device status screen does say that Partition 1 is in "Away" mode.
I tried with "Stay" and that didn't work and I tried testing the status and then the time but that didn't work either. "Security" makes no difference.
If its not a plug-in issue, then I suspect that the status is only true on a change, and not a continuous state. If so, how to you test for a continuous state?
