How to get status on Aeon Panic button in HS3?
    I'm going mad, had tried this for days but can't get status on the panic button
    I had set parmeter 250 to 1. (scene controller). It's associated with homeseer (ID1)
    I erased my z-wave stick and it has only one device, this one.
    Whats next? Creating scenes or what, don't get it.
    Current Z-Wave Networks
    Network Friendly Name HomeID Number of Nodes Interface Name Interface Model Node ID
    Network 0184D3AE 0184D3AE 2 Aeon Z-stick II Aeon Labs Aeotec Z-Stick 1
    Node Information for Network 0184D3AE
    1 Full Name: Node 1 Z-Wave Aeon Polling: Polling Disabled
    Manufacturer:
    Sigma Designs Type:
    0x0 ID:
    0x0 Listens:
    No Version: (Not Available) Neighbor Rating
    *Poor (0) This rating is based upon 2 nodes in the network, and out of those nodes, 0 are within range to be neighbors to this node which means they can be used to help route to/from this node. Speed:
    40.0Kbps
    Basic Type: CONTROLLER, Generic Type: STATIC CONTROLLER
    2 Full Name: Node 2 Z-Wave Aeon Labs Generic Controller Node 2 Polling: Polling Interval: 12h, 0m, 0s
    Manufacturer:
    Aeon Labs Type:
    0x1 ID:
    0x26 Listens:
    No Version: 2.78 (ZDK 5,02.3 Patch 3) App: 1.12 Neighbor Rating
    40.0Kbps
    Uses Interface: Aeon Z-stick II (1) Basic Type: CONTROLLER, Generic Type: GENERIC CONTROLLER, Specific Type: PORTABLE REMOTE CONTROLLER
    Command Classes:
    Supported: Version, Manufacturer Specific, Configuration, Battery(V 1), Wake Up, Association
    Controlled:
    Scene Activation, Switch Multilevel
    Regards
    Lunkan
    Not so important anymore, bought an another device.
    Just want you to know that Benext panic watch works with HS3.
    Notification, Reset notification and battery level works.
    Then this Benext panic button should possible work with HS.
      Whoo, was reading around the forum and saw that aeon labs panic button should work now. Tested and YES it did. (status is always on but do an event and it will work) My button is not a Z-wave plus unit. (EU version)
      (Note: Can't get the Benext panic button to work right now but aeon labs button is better anyway)
      Z-wave plugin ver: 3.0.1.50
