Ok so a guy I work with does not use Homeseer; however, he is using a Samsung SmartThings v2 which Alexa is tied in. He said he can do double tap... and I'm curious if and/or how you do this in HS?
he said..
Double Tap is only with the custom device handler. The one built-in to SmartThings does not access it. It's a SmartThings thing. Way to put in custom code rather than use their own code.
so I'm new at this end and don't know anything about it... curious if someone can shed some light. Is this due to the Samsung SmartThings ability? will I be able to do this as well?
he pointed me here, where this guy says the switches support double tap... ?
https://community.smartthings.com/t/...-options/85234
he said..
