Is there anyway to programatically reset a sign, as can be done from the Options, Sign page? Im ocasionally getting a sign freeze, and wonder if a nightly reset may help?
Reset
anogeeTags: None
anogee
An action would be real good, because then I can easily us it from my once-per-night event trigger.
I'm not sure why, but my weather message which contains several strings, seems to occasionally be locking up one of my signs. When this occurs it no longer responds to the remote, but it does seem to respond to the reset. I've looked at the message with the message viewer, and it looks fine. I will try turning off the verify option since this still doesn't prevent the occasional missing string, and it may be confusing the sign.
anogee
Bill:
I need a refresher on that. It used to be you could run &hs.plugin("LEDAM").SignReset from the run scripts command, but it doesn't look like it in my version. 2.2.0.11
anogee
anogee
O.K. What am I still doing wrong?
Added this: &hs.plugin("LEDAM").SignReset
Under the Script Statement section of an event.
5/3/2007 7:49:29 PM - Error - Running script, init error: Object doesn't support this property or method: 'hs.plugin(...).SignReset'
5/3/2007 7:49:29 PM - Error - DV_Request general error: InvalidOperation_EnumFailedVersion, HS2Util
5/3/2007 7:49:29 PM - Error - CheckTriggerStatusChange (DE) error, Object reference not set to an instance of an object., Scheduler
anogee
Thanks. That is probably the problem. I just had to roll back to an older version, but the good news is, this version doesn't "lockup" so don't need the reset with this version.
