You are doing a great job of this plug-in ... thanks. Perhaps it takes more programming on my side, but is there a way to restore the current audio once the HS has spoken through AirSpeak? Right now it stops the currently playing track / internet radio station when it speaks.
Airplay Speak - HS2 Beta Testing
Originally posted by qmcgrath View PostYou are doing a great job of this plug-in ... thanks. Perhaps it takes more programming on my side, but is there a way to restore the current audio once the HS has spoken through AirSpeak? Right now it stops the currently playing track / internet radio station when it speaks.
With what type of device do you have this problem?
Originally posted by Fischi View PostHi Spud,
At next I want to buy a cheap solution for an airplay system/speaker,
only for messages over airplay.
Which solutions do you recommend ?
Another very cheap solution (which I haven't tested myself yet) is the Raspberry Pi ($35) on which you can install shairport (http://trouch.com/2012/08/03/airpi-a...ith-raspberry/) or even a full media center compatible with airplay like XBMC (http://wiki.xbmc.org/index.php?title...nstalling_XBMC)
Not sure what is the best way to handle this issue. Maybe I could trigger some events before and after the announcement is played, and then it would be your job to find a way to react to those events to turn on/off the device or stop/resume what the device is currently playing.
Does that sound a good idea?
Originally posted by stboch View PostCalling GenPage for plugin, link: /airplayspeak_config Error: Object reference not set to an instance of an object.
1.1.0.7
When does it happen?
Does the plugin discover any airplay device? You can see that in the logs
Do you have any event configured?
Was it working with a previous version?
Could you attach your full log?
thanks
Guest
Just giving this plugin a try and get this error when loading the config page.
29/04/2013 20:28:46 Error Calling GenPage for plugin, link: /airplayspeak_config Error: Object reference not set to an instance of an object.
29/04/2013 20:28:34 AirplaySpeak Resolved Service: B827EB182545 - XBian - 192.168.85.13 - 36666
29/04/2013 20:28:34 AirplaySpeak Found Service: B827EB182545@XBian
29/04/2013 20:28:34 Plug-In Finished initializing plug-in AirplaySpeak
29/04/2013 20:28:34 Plug-In Initializing Plug-in: AirplaySpeak
29/04/2013 20:29:12 Error EV_Request error with ByGroupAndName: Object reference not set to an instance of an object., Scheduler
29/04/2013 20:29:12 Error EV_Request error with ByName: Object reference not set to an instance of an object., Scheduler
29/04/2013 20:29:12 TTS Speak: ():Brian! It is time to get up for work
29/04/2013 20:29:12 AirplaySpeak (XBian): Brian! It is time to get up for work
Hi Spud,
I've downloaded and installed v1.1.0.9 on my Hometroller. Bonjour was also installed from the link you provided. I have one airport express (wireless, connected to my home network) and one Apple TV (turned off during my experiments).
I've created two events, one with text and another one with MP3 file.
The problem i'm reporting is, for both events, the sound goes on and off intermitently - plays 1 second, silent (skips) 2 seconds, plays 2 seconds, silent (skips) 3 seconds, etc.. I thought the unit was in problem, but it worked flawlessly with iTunes right after. I monitored CPU usage on my Hometroller and it showed 23% on average, far from being too busy.
I enabled debug in your plugin. I've included some files to look at! I hope you have enough information to work with. If not, just let me know what I must do.
Thank you in advance!
Richard
