I have two of these devices in the same electrical box, one to control an outside light and another to control our living room light. The outside light responds to z-wave commands, however when it's on it glitches off and then back on again. Thankfully when it's off it doesn't glitch on. I tried removing the device from the network and then re-adding it, same problem. Then I tried to do it again and now it won't remove...
The switch that controls our living room light is stone cold dead. The LED isn't on and it doesn't respond to anything.
I purchased these devices from Tigerdirect.ca mid-September of last year and looked into the warranty, there is 1yr warranty. I contacted the manufacturer, Nortek Security and Control, and to my surprise they won't honor the warranty as Tiger Direct doesn't distribute their product anymore...
Could this be a Z-wave plugin maybe causing the issue with the glitching light? Any suggestions? I am trying every avenue to see if it can be something I can fix, since it seems Nortek doesn't want to warranty their products.
Edit: I'm running the latest HS3 and went from 3.0.1.89 to 3.0.1.90
