Originally posted by jon00
View Post
Jon00 HTML to Image Utility
Sure, not a problem Jon.
I set the following in the Jon00VDGraphingHS3.ini
Code:TableWidth=1000 TableBackGroundColor=Yellow
This is the file that is produced using the Jon00HTML2ImageHS3
If you need me to post the INI files, let me know.
Thanks for your help it is appreciated.Billy
Originally posted by jon00 View PostYes, would you post the entire ini section used to produce your graph.
This is the section in the Jon00HTML2ImageHS3.ini file
Code:[Capture3] URL=deviceref 2435 DeviceBGColor= ImagePath=<hspath>\html\images\BJD\Jon00HTML2ImageHS3\capture03sumppump2.png crop= WBWidth= WBHeight= Delay=
Code:[Graph4] Title=Sump Pump #2 Textbeforevalue= Textaftervalue=" Level" Units= Backgroundcolor=#b6bdc6 Imagefile=Green.gif Samplesize=288 Height=40 Heightspacer=3 Tooltips=1 Maxvalue=4 Minvalue=0 Data=$DV:2153 Dataoffset= Logging=0 ShowCurrentValue=2 ShowLowHighValues=1 ShowAverageSessionValue=1 DelayCount=1 DivideValue=1 MarkerHeight=40 MarkerSetPoint= MarkerDuration=24 MarkerImageFile=white.gif MarkerType=1 StartTime= FinishTime= TimeImageFile=blue.gif Counter=1 Zoom=2 TableWidth=1000 TableBackGroundColor=Yellow Range1Upper=1 Range1Lower=0 Range1ImageFile=blue.gif Range2Upper=2 Range2Lower=1 Range2ImageFile=green.gif Range3Upper=3 Range3Lower=2 Range3ImageFile=orange.gif Range4Upper=4 Range4Lower=3 Range4ImageFile=red.gif
Thanks again for all you do, it is appreciated.Billy
I am trying to figure out a capture problem.
Thought I could fix it by editing a css file.
https://forums.homeseer.com/showthre...=95611&page=12
At post # 227
TimFB Page - https://www.facebook.com/pages/Capt-Tim/209398425902188
HSTouch Layouts - https://www.facebook.com/media/set/?...5902188&type=3
Thanks, Jon.
That didn't work. I'll keep looking.
Jon, should this plugin work in the Linux version of HS3? I'm running Mono 5.4.1.6.
I installed and configured it as you documented, but in my log I get a messages "Jon00HTML2ImageHS3.exe file not found". Is it possible it is looking to find it in a specific directory? I put it in the root directory with the rest of my plugin exe's. My HS3 root is "/usr/local/HomeSeer/"
Jan-07 11:38:45 AM Jon00_HTML2Image Jon00HTML2ImageHS3.exe file not found
Jan-07 11:38:45 AM Event Running script in background: /usr/local/HomeSeer/scripts/Jon00HTML2ImageHS3.vben("Main","1")
Jan-07 11:38:45 AM Event Event Trigger "Testing Jon00 Image converter"
HI Jon, i am running your HTML to image script. Its great by the way !!)))
However, i keep getting errors. See error log text below. Any suggestions?
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Threading.ThreadAbortException: Thread was being aborted.
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at System.Windows.Forms.UnsafeNativeMethods.CallWindowProc(IntP tr wndProc, IntPtr hWnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at System.Windows.Forms.NativeWindow.DefWndProc(Message& m)
at System.Windows.Forms.Control.DefWndProc(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.WebBrowserBase.WndProc(Message& m)
at System.Windows.Forms.WebBrowser.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(M essage& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Mes sage& m)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.7.3362.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
Jon00HTML2ImageHS3
Assembly Version: 1.0.0.0
Win32 Version: 1.0.0.0
CodeBase: file:///C:/Program%20Files/HomeSeer%20HS3/Jon00HTML2ImageHS3.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.7.3062.0 built by: NET472REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
Win32 Version: 4.7.3324.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.7.3221.0 built by: NET472REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
