That is something I don't have any control over really, I have no idea what is in the iOS/android programming code on the Pushover application. I can say it works on my iPhone and android tablet and when I receive notifications the devices do wake up or at least wake up from the home screen and then go back to sleep again. If you are having problems then you can contact Pushover support here https://pushover.net/support who should be able to help.
Pushover (3P) Plugin
Guess you'll have to change some things in your plugin :P
http://updates.pushover.net/post/870...new-priority-2
Originally posted by tCC View PostThanks!
Maybe it's more handy to start label them with -2 Lowest, -1 Low, 0 Normal, etc names ? (see attachment for current sorting).
And I cannot get "Send Message On HS Startup" to work, every time I select that option and click "Update Information", the checkbox is unticked.
https://www.dropbox.com/s/anzpz83zb8...I_PUSHOVER.dll
Originally posted by rmiles7721 View PostJust wanted to say thanks for the plugin.
I'm already using Eventghost, Autoremote and Tasker for more involved stuff but this works like a charm for quick notifications. I'm not planning on switching to HS3 yet so this was nice to find.
I'd like to use the plugin in a HS2 vb script. Can you recommend how to do this?
RobHS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostI'd like to use the plugin in a HS2 vb script. Can you recommend how to do this?
RobPublic Sub PushMessage(ByVal Message As String, Optional ByVal Title As String = Nothing, Optional ByVal Priority As Integer = 0, Optional ByVal Sound As Integer = -1, Optional ByVal sURL As String = Nothing, Optional ByVal sURLTitle As String = Nothing, Optional ByVal sTimeStamp As String = Nothing, Optional ByVal DeviceName As String = Nothing)
Which in short means a call of;
hs.plugin("Pushover (3P)").PushMessage("Test Message") will send a simple message with no title, no priority, no sound, no additional URL but if you fill in the additional parameters then you can specify those if you do want.
Thanks... I seemed to have figure most of it out. Can you provide an example with the timestamp? Not sure of the syntax here...HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
Originally posted by langenet View PostThanks... I seemed to have figure most of it out. Can you provide an example with the timestamp? Not sure of the syntax here...
The code is this;
Code:If sTimeStamp IsNot Nothing Then Call WriteMessage("sTimeStamp Value Specified", MSG_DEBUG) If DateTime.TryParse(sTimeStamp, tmeConvert) = True Then unixTime = TimeToUnix(tmeConvert) colValues.Add("timestamp", unixTime) Else Call WriteMessage("Unable To Parse Date/Time in TimeStamp", MSG_ERROR) End If Else Call WriteMessage("No sTimeStamp Value Sent", MSG_DEBUG) End If
Perfect... thanks for all your help - again!HS3PRO 3.0.0.500 as a Fire Daemon service, Windows 2016 Server Std Intel Core i5 PC HTPC Slim SFF 4GB, 120GB SSD drive, WLG800, RFXCom, TI103,NetCam, UltraNetcam3, BLBackup, CurrentCost 3P Rain8Net, MCsSprinker, HSTouch, Ademco Security plugin/AD2USB, JowiHue, various Oregon Scientific temp/humidity sensors, Z-Net, Zsmoke, Aeron Labs micro switches, Amazon Echo Dots, WS+, WD+ ... on and on.
