Hello,
I am new to the BLstat program. I have a CT 100 thermostat. All seems well except when I make a manual change to the set temp, the schedule does not resume until the next scheduled time change. I want the time to force the temp back to the schedule temp after the specified amount of time. Under manual set point changes, I have tried different combinations of the 3 options but none seem to work. Can someone tell me which 3 options should be checked? I would like the system to allow a user to change the temp at the thermostat and have it start the timer for the specified period of time. When that time passes, I want to temp setting to return to the temp in the schedule. I've checked the actively log and there is no attempt to return the temp after the time that I set passes.
Thank You
Thank You
