Setup
Plugin: Harmony Hub Get Devices ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux_arm.exe', CommandLine='xxxxxxx@xxx.com xxxxxxxxxx 192.168.2.84 list_devices_raw', CurrentDirectory='', Native error= Access denied-
i assume it is stating my password is incorrect. i didn't want to show it. i have the same password on the hub as the config page so not sure what is happening.
Originally posted by serky View PostPlugin: Harmony Hub Get Devices ApplicationName='/usr/local/HomeSeer/bin/HarmonyHub/harmonyhubcontrol_linux_arm.exe', CommandLine='xxxxxxx@xxx.com xxxxxxxxxx 192.168.2.84 list_devices_raw', CurrentDirectory='', Native error= Access denied-
Open a session to your ZEE and execute the following 2 commands:
Code:cd /usr/local/HomeSeer/bin/HarmonyHub/ sudo chmod +x harmonyhubcontrol_linux_arm.exe
Rien du Pre
The Netherlands
Using:
Plugin's:
RFXCOM, mcsMQTT, Z-Wave
Can I do this from a MacBook?
I tried with terminal and received this:
Jasons-2016-MacBook-Pro:~ jason$ cd /usr/local/HomeSeer/bin/HarmonyHub/
-bash: cd: /usr/local/HomeSeer/bin/HarmonyHub/: No such file or directory
Jasons-2016-MacBook-Pro:~ jason$ sudo chmod +x harmonyhubcontrol_linux_arm.exe
Password:
chmod: harmonyhubcontrol_linux_arm.exe: No such file or directory
Yes.
But you first have to setup a ssh session to the zee using Terminal.
Like ssh pi@192.168.0.185
In you're in, execute the commands
Password:
Jasons-2016-MacBook-Pro:~ jason$Regards,
Rien du Pre
The Netherlands
Using:
Plugin's:
Mac Access
Hi Serky,
I had very similar challenges to you. I am also using a Mac. here's what I did:
(1) Open up a terminal window (Go to Applications, Utilities, Terminal)
(2) check your router to see the IP address for HometrollerZee or other Hometroller device
(3) Type ssh homeseer@192.168.1.114 (or whatever your IP address was from step (2).
(4) Enter a password. Either "hsthsths3" if you haven't changed it, or your new password.
(5) Then type "cd /usr/local/HomeSeer/bin/HarmonyHub/" and hit return
(6) then type "sudo chmod +x harmonyhubcontrol_linux_arm.exe"
(7) Then go back to your Homeseer Webpage and go to Manage Plug-ins.
(8) First disable, then re-enable the Harmony plug-in.
(9) Go to your Harmony plug-in Device page and you should see your activities and devices. Let me know if you get stuck. -- Bob
Bob,
Thanks so much. I see the Hub now. That was awesome.
If you don't mind and can lead me in the proper direction:
How would I create an event? For example when I use the Harmony to turn the TV on, I would like Homeseer to run the music off button.
I have been trying to set this up but am unclear without a little more direction.
Jason
