I have maxed out my Hue Bridge and would like to add another. Is it possible to use JowieHue to move lights form one bridge to another one light at a time?
Moving lights between bridges?
ajgyomber
You should be able to do this now with the new beta (found in the beta section of the manage plugins page). But do take the one by one litterally?
You have to use the touchlink procedure on the configuration page for the bridge that will get the new light. Once the light has been blinking, you can scan for a new light.
The light should then be imported in the plugin where the plugin will make sure the light is removed from the old bridge. It will also make sure the old name of the light is used on the new bridge and events and devices stay the same.
If you have two or more lights moving to the new bridge, the plugin will have an issue and cannot move the lights correctly. You will then have to stop the plugin and remove the devices from the device list by hand. After restarting the plugin, the light will then be added as new lights.
Wim-- Wim
