Hi all-
I added 6 new HS WS100+ switches and a few WD100+. After adding them to the network the whole thing is now unstable. Prior to adding them I have about 30 (mostly Cooper) devices and an array of other things.
As to unstable, I mean that I cannot reliably control the devices. Strangely, the new HS devices seem a lot more stable than the Cooper ones.
I have performed multiple full optimizations, some of which seem to throw the Z-Net into a red LED state, and the optimize stops. I am also finding this repeating in the logs:
Oct-20 7:45:45 AM Error Posting back to plugin web page ZWaveConfig: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
Oct-20 7:45:45 AM Error Posting back to plugin web page ZWaveControllers: Object reference not set to an instance of an object.-> at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(IMessage msg) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Mess ageData& msgData, Int32 type) at HomeSeerAPI.IPlugInAPI.PostBackProc(String page, String data, String user, Int32 userRights) at Scheduler.proxyPage.postBackProc(StateObject& state, String Data)
[EDIT] For the above errors I just found the zwave pluging crashed on the server and restarted. This is not the first time this has happened.
I just installed .150 zwave plugin (from .130) - it did not help.
I have also tried that "Reset Z-Wave Data" button. No new help there.
Any thoughts on a path I should take to stabilize things? Suggestions would be much appreciated.
Thanks in advance,
John
Thanks in advance,
John
