Since a couple of week I have a strange X10 problem.
I have four switches next to each other. 3 of them are Marmitek LW11 dimmer modules and 1 is a SW10. All 4 switches doesn't react on any X10 command, if a lamp which is on the other side of my living room is switched off. If this lamp is on all 4 off them react as normal on X10 commands.
All of them (including the lamp) are on the same power group)
In the past this was working without a problem, and I cannot think of anything which has been changed when this problem was introduced.
I have the idea that it has something to do with signal strengt, because my X10 meter gives an X10 signal error when the lamp is of and around 100mv signal when the lamp is on.
All comments are welcome,
