Current Date/Time: 11/22/2017 1:40:38 PM
HomeSeer Version: HS3 Standard Edition 3.0.0.368
Operating System: Microsoft Windows Embedded Standard - Work Station
System Uptime: 1 Day 3 Hours 27 Minutes 40 Seconds
IP Address: 192.168.1.215
Number of Devices: 271
Number of Events: 29
Available Threads: 200
Enabled Plug-Ins
3.2.0.5: APCUPSD
2.0.38.0: BLLAN
3.0.0.101: LutronCaseta
3.0.6331.36036: UltraCID3
3.0.6370.28796: UltraM1G3
3.0.1.130: Z-Wave
I receive the following errors when running Z-Flash. The last change I made was installed a new Z-NET as my controller.
Initializing Z-Wave interface (Ethernet Interface) at 192.168.1.217, port 2001
Z-Wave Ethernet at IP 192.168.1.217, connected to interface ok.
Processing data buffered by the interface while it was disconnected.
Getting node information from controller...
: Exception transmitting to IP 192.168.1.217: Unable to write data to the transport connection: An established connection was aborted by the software in your host machine.
: The interface did not respond to the request for the HomeID and Node - it may be disconnected or malfunctioning (2).
Trying to re-connect to Ethernet interface at IP 192.168.1.217...
Init Done.
Enabled Plug-Ins
3.2.0.5: APCUPSD
2.0.38.0: BLLAN
3.0.1.130: Z-Wave
Init Done.
