The work around is fine. In fact, if you click on the name of the z-wave plugin on the plugins page you will be on a config page. From there you will see a "Reset" buton. This button does the procedure you posted.
The information in the Z-Wave DB is duplicated in the HS DB for each device. So if you delete the Z-Wave db, it will be rebuilt from the info in HS. Ideally we should somehow detect the error that you saw and fix things automatically. Something we are working on adding.
Originally posted by raymonvdm
View Post
