I have a FortrezZ Mimolite setup and working for opening and closing my garage door. I'm trying to wire the input into the trip sensor, but I'm having difficulty figuring out the configuration values.
This manual has a range of values in "ADC Counts", which I need to convert to an 8 bit value:
https://static1.squarespace.com/stat...MI+address.pdf
I've also tried their configuration helper, but it only goes up to 5.87 volts. Also when I go to "Configuration Parameters to Program" the decimal value appears to be much higher than what is found in the chart - it says 4080 is 6 volts, but the chart says that is about 14.5 volts... the config utility does say MIMO2+, so perhaps that's why?
The trip sensor reads 5.8 volts when unobstructed and 6.2 volts when there is something blocking it.
Anyone know what values I have to configure to get that working?
My goal is to provide a status when the trip sensor is being blocked.
I plan to do an open/close status using a tilt sensor or some other wireless sensor later on.
