Hi Spud,
Wanted to try your plugin but wanted to clear up a few things first.
- Can I use a XBox 360 Kinect on a windows 7 PC or would I need a window version.
- If I can use a XBox 360 Kinect on a windows PC which of the 2 drivers would I need
- I would like to use the Kinect on my always on server where Homeseer is running, but the Kinect unit would be in my cinema room, now I suspect I wouldn't be able to use echo cancellation due to my HTPC being a different PC
in version 3.0.0.16 available here, I have added echo cancellation
To enable it, go to the config page, in the Voice Recognition tab tick the "Echo Cancellation" checkbox then restart the plugin.
This will filter out all the audio from your default speakers (the audio output which is set as default in Windows)
