I've been fighting my iTach IP2IR for over a month now. Don't know if I will get it to work or not. Too bad HST dropped the Ocelot support for IR and X10. Don't know what the answer is.....
SQ Blaster Plus
Originally posted by Sonn View PostThe answer is >>>>Have someone update the IR code for the Ocelot for HS3, I'm working on that...
How tedious is programming HS3 with global cache, for each IR command? Do you have to program each remote control button command separately? I'm guessing so, and not a big deal as long as each button is just minutes, not hours. And standard programming options ( I don't want to do custom scripting).
Originally posted by Oilbelcher View PostHow tedious is programming HS3 with global cache, for each IR command? Do you have to program each remote control button command separately? I'm guessing so, and not a big deal as long as each button is just minutes, not hours. And standard programming options ( I don't want to do custom scripting).
