Graph One wire Temperature sensors
I use Jon00's Database Charting script and have used skWare's Device History plug-in. They both will do what you want.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by DrZWave View PostJon00 unfortunately only works on Windoze and I have a Zee S2 (Raspberry Pi so it is running Linux). And all I want are simple graphs of mostly temperature that goes back as far as the log file has data. Anything out there that will do that?
Here is the page to generate a chart and all the data collected.
It makes decent temperature charts with adjustable sizes and styles.
This software plug-in is designed to allow HomeSeer3 to track the historical values of the specified devices and display them in chart and table formats. It provides GUI, event, and...Last edited by randy; August 11, 2018, 03:45 PM.HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostI use Jon00's Database Charting script and have used skWare's Device History plug-in. They both will do what you want.
[QUOTE=khriss75;n1239600]Aluis, if you want You can tray emoncms.org
Simply send the data on server and then graph all you want. You can manage data/graph by day, month, year... you can elaborate your data with math expression...
Database is not on your server but you can download it.
Would you be so kind to provide more details of how to get the data out of HS3 and pass it to emoncms.com
Originally posted by risquare View Post
Which one is better in your opinion and why?
Steve has been adding features and flexibility to Device History, so it gets better all the time.
As written above Jon's is Windows only.
If I had to chose one, it would be difficult.I initially started with Device History.
[QUOTE=risquare;n1241387]Originally posted by khriss75 View PostAluis, if you want You can tray emoncms.org
Code:Sub Main(parm As Object) Dim consumo_Wh_giorno As String = hs.DeviceValueByName("CONSUMI consumo_giorno_Wh") Dim stringa stringa = "input/post.json?json={Consumo Watt giorno:" & consumo_Wh_giorno & "}&apikey=xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" hs.geturl("http://emoncms.org/", stringa, False, 80) End Sub
After a registration on emoncms.org, you have a personal API KEY.
You can see the documentation on the site.
Originally posted by bdraper
I have used Jon's Database Charting application ever since he created it. It is a great application that provides a wealth of functionality and is very configurable. The only downsides I see are the limit of 10 database fields per database, not being able to graph items across different databases and it could be one of those packages that is just too configurable (LOL). These rarely cause me any issues any issues, actually the configuration part, I think it is great that it has so many options and on some of my databases I just graph a value multiple times in several databases... for instance I graph a lot of room temperatures, and compare them to the outside temp, so I store the outside temp in multiple databases.
Included below are a few of the graphs that are produced daily on my system.
This is a graph of our HVAC runtime and cycle information.
This is a graph of Power usage information at our main panel from a ZW095 - Aeotec Home Energy Meter.
This is a graph of the outside humidity and temperature compared against temp sensors in our attic and crawlspace.
This is a graph of the outside temperature compared against temp sensors in our bonus room temp and HVAC ceiling register.
In an attempt to get a handle on the number and types of events that were executing during the day, I setup 8 categories to record some data. In order to achieve the results below a group action was setup for each event group name. I have my events group into roughly 40 group names. Of those 40 group names, I categorized the the events into 8 graphing categories.
I hope this helps...HS4 Pro, 4.2.19.16 Windows 10 pro, Supermicro LP Xeon
Thanks Randy, I converted graphics to images and uploaded them via the bulletin board utility, maybe this will work better. Before I used cut-n-paste... looked good from my view. Strange... Let me know if this does not work...
Billy
Originally posted by bdraper View PostThanks Randy, I converted graphics to images and uploaded them via the bulletin board utility, maybe this will work better. Before I used cut-n-paste... looked good from my view. Strange... Let me know if this does not work...
Code:http://starbase01:8080/images/jon00/dbchart/chart005.png
