In my shop, I have 162W LED linear high bay lights, wired 3 per switch.
The HS-WS200+ specs list 1800W (15 amp) resistive load but only 200W LED/CFL load.
Since this is a switch and not a dimmer, is there a reason why the LED load spec is so much lower than the resistive load?
I haven't opened one up to look at it, but if the load is switched by a 15A relay, isn't 15 amps = 15 amps regardless of the type of load??
Shawn
Shawn
