Script for Monoprice 6 zone Audio
    I have 3 monoprice 6 zone amps in my house but having trouble figuring out how to send the scripts through the rs232 to control them. I have the manual with all the command but can't figure out how to put it all together.
    Can anyone give me a sample script to control at least 1 function of this?
    Sent you a message with all my scripts but you can use the below script to test
    Change COMPort.PortName to your port and this will turn all zones On machine1 On
    Com = "<10PR01" & vbCr
    To turn off:
    Com = "<10PR00" & vbCr
    Imports System.Threading
    Imports System.IO.Ports
    Public COMPort As New SerialPort()
    Public Sub Main(ByVal parm as Object)
    Dim Com as Object
    Dim rxBuff as String
    rxBuff = ""
    'hs.writelog("Audio", "ScriptCallParm=" & ScriptCallParm)
    COMPort.PortName = "COM6"
    COMPort.BaudRate = 9600
    COMPort.Parity = System.IO.Ports.Parity.None
    COMPort.DataBits = 8
    COMPort.StopBits = System.IO.Ports.StopBits.One
    Comport.ReadTimeout = 1000
    hs.writelog("Audio", "Main() Called - Attempting To Open")
    If COMPort.IsOpen = False Then
     COMPort.Open()
    End If
    hs.writelog("Audio", "Port Open - Sending Data")
    hs.writelog("Audio", "Sending: " & Com)
    'writes to com port
    COMPort.Write(Com)
    System.Threading.Thread.Sleep(600)
    'Reading the com port:
    rxBuff = (COMPort.ReadExisting)
    If rxBuff <> "" Then
    hs.writelog("Audio", "Received:" & rxBuff)
    rxBuff = ""
    End If
    COMPort.close()
    hs.writelog("Audio", "Ended")
    End Sub
    Thanks Steven
      Steven,
      Ok first test was a success. change it to com 4. and edited it to turn on all of zone 2.
      Now for the fun long process of doing like 100 of these to do all 18 zones, at different volumes, on's and off's and so on. LOL
        This is awesome help! Thank you. Since moving to HS3 on linux I've struggled with the syntax to access the tty serial port. I have a monoprice amp and a Nuvo amp. If you have any additional scripts I'd appreciate a PM. I'll post any of my successes as well.
        Thanks again.
          I sent you an email with all my scripts zipped up including screen shots of events
          Let me know if you have any questions.
          Steven G
            Steven,
            Thank you for all of your efforts with this. I just received my Monoprice 6-Zone today. Could I please get a copy of your scripts, so that I can integreate the Amp into my HS3 environment.
              Hi John,
              I've been working on a plugin for the monoprice amp for HS3. Most of it is working. Things I know don't work are the All amp commands for all zones off all zones mute. But all the individual zone stuff seems to work as well as actions. It has a settable poll rate but baud is fixed at amp default of 9600. it only supports one amp. Also I haven't programmed any triggers or conditions yet or any type of scripting interface. I've been running it for a couple days now on a windows 7 machine and nothing has exploded so that's good
              Seems like you might be in a position to try it and provide some feedback. If you're interested I'll send you a copy.
                Originally posted by happnatious1 View Post
                Hi John,
                Hi Happ,
                That would be great! I just took the amp out of the box yesterday. I need to mod my cabinet today to ensure good ventilation. I also need to pick an RS-232 extension cable. I am also running Win7 on an Intel NUC as my HS3 machine. I will use a Trendnet TU-S9 USB/Serial to interface to the amp. I should be all set to go by tomorrow. I will gladly provide testing and feedback. Please PM me with the information. Thanks again!
                  Hi John,
                  Happ,
                  I have my monoprice amp running and would love to provide you with feedback on the plugin. I'm running 5 zones and hs3 on win7. I have a virtual serial port on the hs3 (which is in my office) going over TCP/IP to a raspberry pi that's sitting next to the amp. I'm using ser2net to make the pi into a serial server (besides the music server) to control the amp.
                  Marco
                    Hey Marco,
                    Based on feedback from John I've added the ability for custom source names, of course that broke a few other things. So PM me your email address and I'll update both you guys when it's fixed.
                    Bill
                      Thanks Bill!
                      The plugin has been working great. Let me know when you need me to test anything else.
                        Hi Bill,
                        I'm trying to do the same thing for a SpeakerCraft MZC-88 (8 zones, 8 inputs, RS232 control etc). The MZC-88 has almost identical settings/options (zone ON/OFF, volume, source, pager, treble, bass etc).
                        And I have the RS232 protocol document and the SpeakerCraft emulator software (to generate the correct RS232 command with checksum). For example to switch Zone 1 to source 1 you send "0x55, 0x05, 0xA3, 0x00, 0x00, 0x03" via RS232.
                        I wonder how difficult it would be to add the MZC-88 as an 'option' to this plugin? I imagine it would be a matter of having a different RS232 code table.
                        I'm not very good at scripting or writing plugins but am willing to invest some time to get this working.
                        Currently I use drule's plugin to send RS232 commands via events. But this is a rather clunky way of doing it.
                        Let me know if you are interested in 'expanding' your plugin. Maybe I could look at it myself if I had the code?
                        Thanks, Marty.
                        iCore5 Win 10 Pro x64 SSD
                        HS3 Pro Edition 3.0.0.435 Windows
                        BLOccupied:,Device History:,Yamaha:,UltraMon3:,mcsXap:,Restart:,UltraNetatmo3:, UltraM1G3:,Ultra1Wire3:,BLBackup:,Harmony Hub:,DoorBird:,UltraECM3:,Nanoleaf 3P:,UltraRachio3:,Z-Wave:,SDJ-Health:,BLGarbage:,Blue-Iris:,Chromecast:,Pushover 3P:,EasyTrigger:
                          Originally posted by mminehan View Post
                          Hi Bill,
                          Thanks, Marty.
                          Hey Marty,
                          I've been giving this a lot of thought and the definitive answer is...Maybe?
                          There are two subroutines that would need to be unique, one sends commands and the other polls for status. The status one would need to be totally re-written based on what your amp spits out for status. The command one would need to fit into a target-command-value structure such as "z1-power-off" or "z2-volume-20". The monoprice amp is based on the following script.
                          PHP Code:
                          'Send Parameters in the form target|command|value ie. z1|volume|20
                          targetsa1,a2,a3z1,z2,z3,z4,z5,z6,z7,z8,z9,z10,z11,z12,z13,z14,z15,z16,z17,z18.
                          'commands: power,volume, mute, dnd(do not disturb),balance, treble, bass, source.
                          valueonoffvolume 00-38treble/base 00-14balance 00-20
                          'Don't forget to set the com port
                          Imports System
                          .Threading
                          Imports System
                          .IO.Ports
                          Imports System
                          .Object
                          Imports System
                          .Text
                          Public
                          Dim tcArray(2) As String
                          tcArray
                          parm.ToString.Split("|")
                          Dim target As String tcArray(0)
                          Dim command As String tcArray(1)
                          Dim value As String tcArray(2)
                          hs.writelog("Monoprice Amp""Script called with: "target "|" command "|" value)
                          Dim tcString "" 'this is what will eventually be sent to the com port
                          Dim tcStringBuilder As New StringBuilder("<") '
                          start building tcString
                          Select
                          Case target           'Select Target
                          Case "a1"
                          tcStringBuilder.Append ("10")
                          Case "a2"
                          tcStringBuilder.Append ("20")
                          Case "a3"
                          tcStringBuilder.Append ("30")
                          Case "z1"
                          tcStringBuilder.Append ("11")
                          Case "z2"
                          tcStringBuilder.Append ("12")
                          Case "z3"
                          tcStringBuilder.Append ("13")
                          Case "z4"
                          tcStringBuilder.Append ("14")
                          Case "z5"
                          tcStringBuilder.Append ("15")
                          Case "z6"
                          tcStringBuilder.Append ("16")
                          Case "z7"
                          tcStringBuilder.Append ("21")
                          Case "z8"
                          tcStringBuilder.Append ("22")
                          Case "z9"
                          tcStringBuilder.Append ("23")
                          Case "z10"
                          tcStringBuilder.Append ("24")
                          Case "z11"
                          tcStringBuilder.Append ("25")
                          Case "z12"
                          tcStringBuilder.Append ("26")
                          Case "z13"
                          tcStringBuilder.Append ("31")
                          Case "z14"
                          tcStringBuilder.Append ("32")
                          Case "z15"
                          tcStringBuilder.Append ("33")
                          Case "z16"
                          tcStringBuilder.Append ("34")
                          Case "z17"
                          tcStringBuilder.Append ("35")
                          Case "z18"
                          tcStringBuilder.Append ("36")
                          Case Else
                          hs.writelog("Monoprice Amp", "Target not found: " & target)
                          End Select
                          Select Case command
                          Case "power"
                          tcStringBuilder.Append ("PR")
                          Case "mute"
                          tcStringBuilder.Append ("MU")
                          Case "volume"
                          tcStringBuilder.Append ("VO")
                          Case "dnd"
                          tcStringBuilder.Append ("DT")
                          Case "treble"
                          tcStringBuilder.Append ("TR")
                          Case "bass"
                          tcStringBuilder.Append ("BS")
                          Case "balance"
                          tcStringBuilder.Append ("BL")
                          Case "source"
                          tcStringBuilder.Append ("CH")
                          Case Else
                          hs.writelog("Monoprice Amp", "Command not found: " & command)
                          End Select
                          Select Case value
                          Case "on"
                          tcStringBuilder.Append ("01")
                          case "off"
                          tcStringBuilder.Append ("00")
                          Case Else
                          tcStringBuilder.Append (value)
                          End Select
                          tcString = tcStringBuilder.ToString()
                          Dim Com as Object
                          rxBuff = ""
                          COMPort.PortName = "COM5"
                           COMPort.Open()
                          End If
                          Com = tcString & vbCr
                          COMPort.Write(Com)
                          If
                          rxBuff <> "" Then
                          hs
                          .writelog("Audio""Received:" rxBuff)
                          rxBuff ""
                          End If
                          COMPort.close()
                          End Sub
                          I would say that if you can get this script working with your amp it would go a long way to getting a working plugin.
                          Big thanks to steveng for sharing his scripts.
                            So glad to see this get some movement, I have been running this amp for over a year with my scripts and never got around to making it a plugin.
                            Please let me know if I can help in any way.
                            Steven G
                              MonoAmp
                              For anyone using my Monoprice amp plugin for the 6\4 Zone Amp - I've Released a newer Version
                              https://www.dropbox.com/s/i61qluqxhy...AmpV4.zip?dl=0
                              Please let me know any issues
                              Kind Regards,
                              Mike Pisano
