HDMI SWITCH
    HDMI SWITCH
    I need more HDMI inputs on my Denon receiver. I came to the conclusion that I just need an HDMI Switch, but Z-Wave or Global Cachet IR Controllable. I guess I would prefer Z-Wave, but I don't think there is such a device. Anybody have anything like this installed?
    I was using a cheap IR controllable switch and then an IR controllable matrix, but there were several conflicts with other devices using IR.
    So i've now changed to a RS232 controllable 4x4 MATRIX which works fine and is very easy to implement. It's also controllable by IR if needed :
    https://www.amazon.fr/gp/product/B00...?ie=UTF8&psc=1
      I use a cheap IR controlled one with an IR led mounted directly over the IR sensor because I also had code conflicts. Built from an ESP8266 an IR led and the ESPEasy firmware. I can then send the IR codes by HTTP and I am able to control it for virtually nothing.
        I've been using this one for the last year or so. Works flawlessly with my Global Cache devices.
