Using HS3. I've got a Kwikset lock and a Repeater (which supports beaming) in my garage (out back). I also have a repeater at the back of the house, as close to the garage as I could get it. With HS2 I used to be able to optimize and talk to both devices.
Since moving to HS3 I've realized I no longer can properly talk to the devices. I was able to properly import both into HS3 via my Z-troller (still attached to the HS3 server) so I know the distance is not insurmountable. If I "Test Connectivity" to the repeater, it works. I Optimize, it fails. The deadbolt I can neither test connectivity on nor optimize. I'm assuming I need to get the repeater running smoothly before I'm gonna get the deadbolt.
Any suggestions on things to try?
