SSH Log Errors
    SSH Log Errors
    New Pro2 installed and all I see in the log is:
    Unable connect to the SmartBridgeS1 SSH check the IP address. Error: 192.168.1.14:22....Permission denied (publickey).
    I can ping the box, when I try to SSH I get:
    ssh_exchange_identification: read: Connection reset by peer
    Any thoughts on how I might connect?
      I'm sorry, the SSH doesn't work for now, so just desable it. If you have the pro then you will connect with the telnet. After you need to add manually the switch by following the instruction in the manuel.
      I'm still working to have the auto import working back.
        Am able to connect via telnet, however, import all devices throws an error:
        LutronCaseta ERROR Can't Import SmartBridgeS1 SSH not connected
        Is there a workaround for this?
          Please follow the instruction
          Caseta Documentation
            Sorry old thread bump, but I got the plugin working last night albeit with this error. The LOG file is just riddled with the error.
            Is there a way in the Lutron app to disable SSH? Or in the plugin?
            Didn't see anything about SSH in the documentation PDF
              The SSH is not available anymore, go in the config and unchecked the SmartBridgeS1 SSH Enabled:
                Ah-ha! I see that there now. That sounds like it'll take care of it. Thanks!
