Been using MeiHarmony for a while and it stopped working. I have deleters and added back the plugin a few times with no success. I am getting the following log error when I try and enable my hub. I am using just one hub with it. See log excerpt below. Need help solving this.
Thanks in advance
Bob
ul-20 12:19:46 PM MeiHarmonyHub: Error The Conection to Hub with ID e5e4baa0-f3a4-409e-224c-578425eedf8c failed with stack trace: at System.Threading.Tasks.Task.ThrowIfExceptional(Boolean includeTaskCanceledExceptions) at System.Threading.Tasks.Task`1.GetResultCore(Boolean waitCompletionNotification) at System.Threading.Tasks.Task`1.get_Result() at HSPI_MeiHarmonyHub.Services.HarmonyHubService.GetHubConfig(S tring hubId) at HSPI_MeiHarmonyHub.Services.HarmonyHubService.ConnectionOpen ed(Object sender, ConnectionOpenedEventArgs e) at System.EventHandler`1.Invoke(Object sender, TEventArgs e) at HarmonyHub.Client.Connect(Int32 heartbeatInterval)
Jul-20 12:19:46 PM MeiHarmonyHub: Error The Conection to Hub with ID e5e4baa0-f3a4-409e-224c-578425eedf8c failed with message: One or more errors occurred.
Thanks in advance
Bob
