Originally posted by nfrobertson
View Post
Upgrading HomeSeer 2 to HomeSeer Pro - First cut
Originally posted by Wadenut View PostIt was for this type of thing and other annoyances I gave up on Norton, which I'd used for eons; two years ago and went with Kaspersky Internet Security. Completely satisfied with it.
Norton sucks (sorry). It doesn't catch the real thing, give you fal;se warning and when you want to scan your drive it takes forever!
O you wouldnt believe how excited I am. I have found one important problem.
On the hs phone part, when you hit the # button on the phone I can hear the lady (computer Voice) asking me "how can I help you" but when I say something I am not getting a response. Now this worked before the up grade to pro.
And I still havent found the setting for the message light? but so far everything else is working perfect, a lot better then the older version.
Thank you Homeseer for such a great price on a great product!
danielbodanielbo
Wow, that was one smootp upgrade. Arguably I've only run my upgraded system for 10 mins, but still ..
Thanks for the Rupp, spot on. It worked with no problems whatsoever as far as I can see.
The only one minor issue is that I seem to have lost the definition of Custom Devices that I had created. Any idea how I could retrieve those from the backup?
NicolaiNicolai L
I have upgrade to HSPRO via the provided updater in the first post...
I am now running HSPRO v2.3.0.86...
If I now want to move my setup to a new server with clean install...
I am thinking I install complete installer HSPRO v2.3.0.19 and then before running HS would I install the update in the first post to update back to v2.3.0.86 or do I use the updater HSPRO (full updater) v2.3.0.84 from the downloads section.
I guess an easier way to ask this...
Will the updater provided in the first link to update HS2 to HSPRO v2.3.0.86 also work with fresh install of HSPRO v2.3.0.19... or was it specially created to just upgrade people from HS2?
Originally posted by jon00 View PostAssuming your Settings.ini was overwritten or replaced, you need to re-enter the data under ScriptingReferences= entry as per the horoscope instructions.
Tomorrow turned out to be a few days later.
Did as you said, so simple really, and all is fine. I installed the download of PRO as from the HST Website and it did over right the ini file among other things.
Thanks for your help.sigpic
Originally posted by megatron2 View PostI have upgrade to HSPRO via the provided updater in the first post...
Originally posted by NicolaiL View PostWow, that was one smootp upgrade. Arguably I've only run my upgraded system for 10 mins, but still ..
Nicolai
