Hi guys... I'm hoping someone has run into this same problem and found a solution.
I have 2 network interface cards. One is a 1gigabit (192.168.1.240) connection which connects to the internet and my local network. The other connection is a 10gigabit (192.168.2.1) connection which connects directly to my PC for fast network attached storage.
The problem is when Homeseer setup it auto assigned to 192.168.2.1. I went into the network tab in setup to set up the preferred network and chose 192.168.1.240.
As you can imagine, using Myhs.homeseer.com doesn't connect to the system due to homeseer choosing a connection that is not connected to the internet. This also becomes and issue if you want to use myhs.homeseer.com through the app. Also, using ztool+ on iphone also fails bc it looks for an IP that isn't on the LAN network that my phone is on. Finally... Alexa won't work due to them not being connected tot he internet or LAN
I'm wondering how to change how Homeseer chooses the IP Address. Right now the only way to fool it into choosing the IP I want is to shut down Homeseer, disable the 10gigabit network card, and then start Homeseer again. Is there something I'm missing? How can I fix this issue?
Current Date/Time: 2/1/2017 11:20:02 PM
HomeSeer Version: HS3 Pro Edition 3.0.0.298
System Uptime: 1 Day 10 Hours 4 Minutes 0 Seconds
IP Address: 192.168.2.1
Number of Devices: 141
Number of Events: 33
Available Threads: 1023
Enabled Plug-Ins
3.0.0.1: Alexa
3.0.21.28949: Blue-Iris
3.0.0.68: HSTouch Server
3.0.1.0: IFTTT
0.0.0.28: Pushover 3P
3.0.1.87: Z-Wave
Enabled Plug-Ins
3.0.0.1: Alexa
3.0.1.0: IFTTT
3.0.1.87: Z-Wave
