** BLRF is RELEASED **
    #46
    I need some help from someone who is running the plugin.
    I need someone who has an RF device that will send X10 ALL ON and ALL OFF signals. I do not have one of those remotes here.
    I need to know what you receive in the plugin for an ALL ON and ALL OFF for all house codes.
    Turn on debug logging in the plugin (on the options page)
    Turn on this option on the options web page as well:
    Log Messages Received from receivers to HomeSeer Log
    This will log all data to the HS log. Once you have it all, email it to me if you would.
    Cheers,
    Bob
      #47
      BLRF working - not action on X10 device
      I got the BLRF downloaded and set up. Looks like the Com 3 port is OK, and commands getting to HS3 log, but no action with the TI103 turning an appliance module ON or OFF. I am using the original TI103 plugin (3.0.0.0) because the newer one (3.0.0.1) seems to have a problem. It works OK for commands from the HS3 status page. I have attached the log. Hope this helps.
      I will try to send an ALL ON/ALL OFF log shortly.
      Phil
        #48
        I will check into your issue as soon as I can. Not likely until tomorrow afternoon.
        Cheers,
        Bob
          #49
          Bob, will Blrf have all the bells and whistles as the ACRF plug when finished? I ask because I already have the ACRF plugin, but it seams that I may have to look for a alternitive since I don't know if ever this plugin will be available...
          Hector
          Win.2003 OS, HS3
          MyTrigger,ACRF2,W800,Zwave
          AP800,Honeywell Stat
            #50
            Yes I plan to add whatever people need.
            I am looking at adding RFXCom support next.
            What else do you need in the plugin?
            Cheers,
            Bob
              #51
              I am aware most people have already purchased ACRF2 (myself included a while back).
              I am thinking I will offer this plugin for $20 for the first little bit. That is the price of all my upgrades to HS3.
              What do people think?
              Cheers,
              Bob
                #52
                BLRF Working - HS3 NOT controlling X10
                I send the HS3 log last night, so I thought you might need a clean BLRF log from startup. RF commands are showing up in the HS3 log, but no end response from X10 module. I can't tell you how excited I am to get my RF working again. Bob, you are the best!
                Phil
                  #53
                  OK I will have a look at this first thing when I get home this afternoon. I am work now. I might have a quick look at lunch.
                  Are your X10 devices setup as status only in HS3?
                  I will let you know
                  Cheers,
                  Bob
                    #54
                    Phil
                    That log is not very long. You need to leave debug logging on for longer. I only got the HS startup and that was it.
                    Turn it on and let it run for a bit. Try and capture an ALL ON and ALL OFF for me if you would for each house code.
                    Attach it here zipped
                    Cheers,
                    Bob
                      #55
                      Hey Bob, are you going to add the 'Auto-Fill' feature? Auto-fill from the last unregistered incoming RF transmission. Don't know how else to find the RF code sent from DS10's.
                      Also, $20 is very fair!
                      Bryan
                      Software/Hardware: Win10 Pro, HS 3 Pro, HS Touch, Echo, Edgeport/4, Z-Net w/88 Devices, Insteon PLM w/19 Devices, Nest, GC-100-6, W800RF32A, WS-2080 Weather Station (KMADRACU10)
                      Plug-in/Scripts: Alexa API, BLBackup, BLGData, BLLED, BLLock, BLRF, BLTVGuide, Blue Iris, BLUPS, Current Cost 3P, DirectTV, FitbitSeer, Insteon, Nest, Pushover 3P, Random, Restart, Tasker, UltraGCIR3, UltraWeatherWU, Z-Wave
                        #56
                        There is a option in acrf where you can customize the device pic and the device string. but this may be available in the device management or device status page in HS3 (don't recall which page). That's great to known your adding RFXcom to your built.
                        Hector
                        Win.2003 OS, HS3
                          #57
                          Yes I was thinking about that. For now you can obtain the device address by turning on the "Log Messages Received from receivers to HomeSeer Log" option in the options page. This will log all data received to the HS log. You can grab the address from there.
                          Let me figure out how I will do this.
                          Cheers,
                          Bob
                            #58
                            Bob, quick question, will I have to enter each device again, or will there be a conversion tool of some kind?
                            Hector
                            Win.2003 OS, HS3
                              #59
                              You should be able to do this quite easily in HS3 in the device options.
                              Cheers,
                              Bob
                                #60
                                Yea I was thinking I would do $20 until the end of August. That will give people time.
                                Then it would go up to $29.99 (which is really not that much more) but every bit of saving helps
                                Cheers,
                                Bob
