hooked up speaker and antenna.... Zone 2 is perfect !! ( NR-626 Receiver 1 )
Is anyone else having an issue getting the plugin to work
Originally posted by sweet View PostSoo you are able to control 737? For me it will not receive any commands only status if manualy change something on receiver. I even loaded hs3 fresh onto another pc to test and same results
just sent Blade another finding.. may get better soon..
what return are you using ?? CR/LF ?Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
Originally posted by gearyt View Postno.. cannot even connect yet... 626 is accepting commands
makes no sense to me either... yes, the receiver commands are reflected in the PI, but the PI commands do not change the receiver..
IF you take a look at the Telnet pictures above, there is one minor difference in the format.. maybe a hint as to what the difference is..
every other command looks like it has a cr prior to the command on the 737Ubuntu on the Intel NUC ( 8i5BEK ), 32 G, 250G SSD, V4 Pro 😎
