Weather Plugins
    Weather Plugins
    I'm new here.. What's the difference between all the weather plugins? They're using different data sources? Anything that displays active radar over an area? I keep seeing screenshots or pics of Radar Images, but i'm not sure if that's one of these plugins or what, any advice on choosing?
    Yes using different sources, radar pictures you probley in HS touch and it's probley just pulling a webpage image from a website using an http get command. So in designer you would not need any weather plugin for that. Weather plugins more used for forecast and all the stats.
    I use Weather underground as it uses local stations of my choice from thousands of places including local schools, airports, and peoples personal weather station.
      Here utilize WeatherXML. (years now)
      Does just about anything weather related these days.
        Can you guys help me out? I lost track of this post. Is there a way to auto subscribe to posts you make? That should be a default.
        And, can you help me out with my RSS Weather Feed for Touch? I cannot figure it out. I have found the weather template in designer, but I can't get the RSS to work. I registered for Weather Underground, and have WeatherXML plugin installed as well as the UltraWeatherWU3 plugin installed.
        Here's a different post I asked for help, but I've had no replies.
        http://board.homeseer.com/showthread.php?t=184500
          To subscribe to a thread, in particular this one, click on "Thread Tools" at the top of this page then "Subscribe To This Thread".
