Event that runs a web call
    I want to create an event that when a virtual device is triggered, it runs a web call like the following:
    http://xxx.xxx.x.xxx:xx/admin?profile=1&user=xxx=xxx
    this actually changes the profile on my blue iris server.
    If I run it from a browser, it works perfectly. I'm not even sure how to search the forums to learn how to do this :-)
    Try this as an immediate script command:
    &hs.GetURL("http://xxx.xxx.x.xxx/","admin?profile=1&user=xxx=xxx",False,80)
    replace the 80 with whatever port number you use.
    Cheers
    Al
    PS If that doesn't work there's also the hs.URLAction command. See http://homeseer.com/support/homeseer...elp/geturl.htm.
      Cheers
      Al
      No errors in log.
      as always... thanks for helping Al!
      that didn't seem to work, but I may have done the original cut/paste wrong.
      &hs.GetURL("http://192.168.1.155/","admin?profile=1&user=xxx&pw=xxx",False,xx)
      does this look right, with the final two xx's being my port?
        Originally posted by Tomgru View Post
        No errors in log.
        &hs.GetURL("http://192.168.1.155","admin?profile=1&user=xxx&pw=xxx",False,xx)
        No problem. This command doesn't really provide an error even if it can't connect to the remote server.
        I may have messed up the format. Try:
        &hs.GetURL("192.168.1.155","/admin?profile=1&user=xxx&pw=xxx",False,xx)
        Cheers
        Al
          Cheers
          Al
          sadly,.... nada. any other ideas?
            Try the URLAction ones (POST or GET). You may need to put them in a script file and call the script.
            Cheers
            Al
              Cheers
              Al
              I was afraid you'd say that. look at that... just a tad lost :-)
              could I entice you for just a bit more support? :-)
                Try
                &hs.urlaction("http://192.168.1.155:xx/admin?profile=1&user=xxx&pw=xxx", "GET", "", "")
                  Try
                  you da man! works great. thanks so much.
