I tried changing the targeted framework as well, but all of my HS3 dlls have dependencies on the 4.0 framework.
I have not tried any of the Linux/Mono distributions, so have no way of attempting to modify any tenScripting code that may be dependent itself on the 4.0 framework, something that would be easy to do I believe.
I was hoping that since, I assume, you are using references to the HS3 Linux dlls that you would not run into the dependency issues that I have.
What kind of errors are you seeing? Are they just tenScripting code errors (because I use VB functions not available in the 2.0 framework), or are you seeing dll dependency issues?
tenholde
tenholde
