Hi, how can I create a virtual device that simulate HS thermostat and locks that can be listed by iftt etc.
HS virtual thermostat & lock devices.
Tasker Plugin / Speech Droid
Tonlof | SwedenTags: None
I don't think locks are a massive issue as the control use pairs are quite simple (door lock/unlock) so you probably can do it from a virtual device created in the UI.
With thermostats my understanding is that the device type API is needed on the devices (and likely a parent/child relationship setup) to build them correctly so they appear in HSTouch however there are also control use pairs for thermostats that are a more recent addition so it may be that you can just set these and it works.
