SqueezeBox Plug-In (3P) Discussion area for the SqueezeBox plug-in by PCP. |
February 10th, 2016, 11:29 PM
So I just tried again. BTW, I've serialized the name of my HS3 server and LMS instance. They both still have the same name; which is now HS311441. Here is the log activity for the latest attempt. I never saw any updates to the player area. It just keeps playing the song I've told it to.
Feb-10 22:31:52 | | SqueezeBox Debug | Exiting speechTimer_Elapsed | Feb-10 22:31:52 | | SqueezeBox Debug | Exiting SpeakOutNextInQueue. New status: stopped. PendingSpeechTrackEnd: False | Feb-10 22:31:52 | | SqueezeBox Debug | StopSpeechTimer. | Feb-10 22:31:52 | | SqueezeBox Debug | Entering DisableSpeaking | Feb-10 22:31:52 | | SqueezeBox Debug | SpeakOutNextInQueue - Stopped. | Feb-10 22:31:52 | | SqueezeBox Debug | Entering SpeakOutNextInQueue. Status: stopping. PendingSpeechTrackEnd: False | Feb-10 22:31:52 | | SqueezeBox Debug | Entering speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting SpeakOutNextInQueue. New status: stopping. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | StartSpeechTimer. Duration: 0:1:0 (1000) | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - Stopping. | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - Deleting TTS URLs. | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakOutNextInQueue. Status: started. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | Entering speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting SpeakOutNextInQueue. New status: started. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | StartSpeechTimer. Duration: 0:0:5 (5) | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakProxyUpdateDevices | Feb-10 22:31:51 | | TTS | Speak: (HS311441:livingroom):hello, New Test for Al | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - No LMS player as Client Speaker. | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - Added URLs: | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - SpeakProxy. Remaining Queue Length: 0 SpeakerClient: HS311441 Host: HS311441:livingroom Text: hello, New Test for Al | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakOutNextInQueue. Status: starting. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | Entering speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting SpeakOutNextInQueue. New status: starting. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | StartSpeechTimer. Duration: 0:0:8 (8) | Feb-10 22:31:51 | | SqueezeBox Debug | Entering EnableSpeaking, Client: HS311441:livingroom | Feb-10 22:31:51 | | SqueezeBox Debug | SpeakOutNextInQueue - Starting. Queue Length: 1 SpeechAudioEnabled: False SpeakerClient: HS311441 Speak Host: HS311441:livingroom | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakOutNextInQueue. Status: stopped. PendingSpeechTrackEnd: False | Feb-10 22:31:51 | | SqueezeBox Debug | Entering speechTimer_Elapsed | Feb-10 22:31:51 | | SqueezeBox Debug | Exiting SpeakIn. Queue Length: 1 | Feb-10 22:31:51 | | SqueezeBox Debug | StartSpeechTimer. Duration: 0:0:4 (4) | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakProxyUpdateDevices | Feb-10 22:31:51 | | SqueezeBox Debug | Entering SpeakIn host: HS311441:livingroom, device: 100, Text: hello, New Test for Al , Enabled: True | Feb-10 22:31:51 | | System | Control Panel Immediate Script: &hs.Speak "hello, New Test for Al", False, "HS311441:livingroom" |
February 10th, 2016, 11:31 PM
No files are being created in the C:\Program Files\HomeSeer HS3\html\Squeezebox directory.
They are again. I accidentally had the speak volume set to zero. Everything else is the same, as the original posts, though.
Super Seer
It is supposed to work that way but it doesn't. It will create the speech file and if you take the url that gets created in the LMS server and put it into a web browser it plays just fine. But it does not play thru the player.
February 10th, 2016, 11:32 PM
Super Seer
Look in the media folder. I think they get put there. I will try to mess with this tonight too.
February 11th, 2016, 12:03 AM
Here are the files that are being created by my system. mediaFiles.zip It looks like my instance of LMS is not configured to play wav files, but it plays mp3's just fine. It just won't play them when told to play them by the LMS server. Maybe I should just make a video of what I am seeing?
mp3 plays fine to the clients if I drop it into the LMS media folder. It does not play fine if told to stream it from the web URL of the SB PI.
edit: LMS plays some .wav files just fine, including this very hifi version of a Muse song, linked for troubleshooting purposes. It doesn't play the wav files being created by this PI, though.
https://drive.google.com/file/d/0B6b...ew?usp=sharing
February 13th, 2016, 01:33 PM
Super Seer
Thanks for posting the media files. Will look at them.
February 17th, 2016, 08:10 AM
Super Seer
I was able to play the mp3 file (via the url from hs3). I did not try the wav file as i am sure my lms has not been setup for wav file types nor transcoding to mp3 when streaming (requires installation of lame in lms if i recall)
February 17th, 2016, 10:38 PM
This is really interesting. What values to you think need to be changed in LMS to support the TuneIn URL streaming of the MP3 files being created? I presume you tested in the LMS server via the TuneIn option. My LMS is still pretty stock, but I can try any changes you recommend and report back.
April 7th, 2016, 06:18 PM
So, do you give up? If so, I'd like a refund for my purchase.
Thank you,
Raymond
April 8th, 2016, 11:51 AM
Super Seer
I am curious as well as I have been waiting for this. Also it seems the latest plugin has to be bounced frequently to maintain connection to LMS.
April 8th, 2016, 12:06 PM
I haven't seen this issue. What errors are you seeing related to that?
Cheers
Al
April 8th, 2016, 12:07 PM
Super Seer
Cheers
Al
Not seeing any errors, but notice my HSTouch screens don't update and my russound panels stop displaying info until this plugin is bounced.
If the PI Developer is around, I can look into it deeper to help them out.
April 8th, 2016, 03:28 PM
Super Seer
I (plugin developer) am around. I have been trying to reproduce it without success a few weeks ago. Since i have been extremely busy with work and right now traveling internationally. If had a reproducible case or even a hint of what the issue is, i would certainly fix it. I will look at it again maybe in a week when i plan to work on a few enhancements to the plugin.
September 6th, 2016, 09:10 PM
Seer Plus
Ok, so I was following this thread for a while, specifically because I had close to near the same problem. I am hoping you may have the same issue as me, I too has a Hometroller. Under status, make sure HS3 Dev. is checked. Dev is not developer mode, its DEVICE! This may be completely off, but it worked for me and hopefully it works for you. I know the frustration of spending hours clicking a test speech event and nothing coming out.
October 10th, 2016, 02:10 PM
Super Seer
Reviving this again as I am still not able to get this to work. I see the player updated with the URL where the file is stored and I don't see any errors in the logs (I do see the audio being sent), but the player never plays the file. It does pause the music, silence, and plays the music again. Other clients speak the test TTS too.
I am using squeezelite on a Pi for a client if that makes a difference.
Oct-10 12:34:56 PM
SqueezeBox Debug
Oct-10 12:34:56 PM
SqueezeBox Debug
Exiting SpeakOutNextInQueue. New status: started. PendingSpeechTrackEnd: True
Oct-10 12:34:56 PM
SqueezeBox Debug
StartSpeechTimer. Duration: 1:1:601 (61601)
Oct-10 12:34:56 PM
SqueezeBox Debug
Oct-10 12:34:56 PM
TTS
Speak: (LMS:SqueezeLite):Test
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakOutNextInQueue - Started Speech: b8:27:eb:6d:9a:fb playlist index 1
Oct-10 12:34:56 PM
SqueezeBox (Player_b827eb6d9afb) Debug
SqueezeLite - SpeakerClientSpeakStart. Play index: 1
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakToFile(). Call Duration=00:00:00.1562487
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakToFile mp3 start. cmd: C:\Program Files\HomeSeer HS3\lame.exe args: --silent "C:\Program Files\HomeSeer HS3\html\SqueezeBox\SpeakIn_5.wav" "C:\Program Files\HomeSeer HS3\html\SqueezeBox\SpeakIn_5.mp3"
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakToFile. WAV: C:\Program Files\HomeSeer HS3\html\SqueezeBox\SpeakIn_5.wav MP3: C:\Program Files\HomeSeer HS3\html\SqueezeBox\SpeakIn_5.mp3 Text: Test IsFile: False FileExists: False
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakOutNextInQueue - Added URLs: b8:27:eb:6d:9a:fb playlist add http://10.0.254.205/SqueezeBox/SpeakIn_5.mp3
Oct-10 12:34:56 PM
SqueezeLite - SpeakerClientSpeakAddURL. URL: http://10.0.254.205/SqueezeBox/SpeakIn_5.mp3 Play index: 1
Oct-10 12:34:56 PM
SqueezeBox Debug
SpeakOutNextInQueue - SpeakProxy. Remaining Queue Length: 0 SpeakerClient: LMS Host: LMS:SqueezeLite Text: Test
Oct-10 12:34:56 PM
SqueezeBox Debug
Oct-10 12:34:56 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeLite - SpeakerClientEnable. speakVolume: 100
Oct-10 12:34:55 PM
SqueezeBox Debug
Entering EnableSpeaking, Client: LMS:SqueezeLite
Oct-10 12:34:55 PM
SqueezeBox Debug
SpeakOutNextInQueue - Starting. Queue Length: 1 SpeechAudioEnabled: False SpeakerClient: LMS Speak Host: LMS:SqueezeLite
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Oct-10 12:34:55 PM
SqueezeBox Debug
Entering SpeakIn host: LMS:SqueezeLite, device: 0, Text: Test , Enabled: True
Oct-10 12:34:55 PM
Event
Event Trigger "Admin Events LMS Test"
October 19th, 2016, 10:35 AM
Super Seer
PCP, are you still supporting this plugin?
October 23rd, 2016, 11:18 AM
Super Seer
Yes I am. I am not using any PI and haven't been able to reproduce this.
October 23rd, 2016, 11:54 AM
Super Seer
Ok. Maybe get a Pi and try? Clearly I am not the only one that paid for this plugin and have a bug, unless you are taking the stance that nothing is wrong?
October 28th, 2016, 03:50 PM
Seer Plus
I use on a Pi and it works, however I use a PiCorePlayer to run Squeezebox on a Pi 3. Try out PiCore, I like it because it doesn't require any head and is super light. It can do most DAC's and never has crashed.
October 29th, 2016, 05:01 PM
Viewer
solution for TTS ?
I use four PI3 with Max2play solution. I had exactly the same problem, the music playback was normal on each squeezelite but no TTS. I use HifiBerry amp+ sound cards on each PI to connect wired speakers. I tried to change the output sound of PI3 and it worked for TTS (PI headphone out or bluetooth). Today, I used these settings and it works for TTS on my sound cards that accept MP3 only 44.1 or 48 Hz.
Speaker Client LMS
TTS as MP3
TTS MP3 Lame options --resample 44.1 -b 160
TTS Voice Microsoft Hortense Desktop - French
TTS Additional Speech Duration 1000 Milliseconds
Delay Before Speaking 0 Hours 0 Minutes 2 Seconds
Delay After Speaking 0 Hours 0 Minutes 3 Seconds
I have other problems but I'll post later. PCP, I think you should acquire a PI with this sound card to test your plugin because it's a great solution for multiroom low cost with proper quality.
Thread Tools |
Display Modes |
Linear Mode
HTML code is On
