Old January 2nd, 2017, 11:49 PM
tome10 tome10 is offline
Getting Started
I don't actually have a Squeezebox. Do I need one? I downloaded Logitech Media Server, and signed up with Pandora, Installed the HS3 Plugin. When I couldn't get anything to work, I determined I needed a Player, so I downloaded something called Softsqueeze, but it says it can't find the server. All of this is running on my Hometroller box. Do I need an actual Squeezebox? I'd rather just have a software version of anything that can integrate pandora with HSTouch.
Old January 3rd, 2017, 01:12 AM
sparkman's Avatar
sparkman sparkman is offline
You can just use the software player. If it can't connect to LMS, it might be a firewall issue on the system it is running on. Try disabling the firewall on it.
Sent from my Phone using Tapatalk
Old January 3rd, 2017, 01:24 AM
Multiple Status Tracking Box
deleted
Old January 3rd, 2017, 07:29 AM
pcp pcp is offline
Super Seer
Originally Posted by tome10 View Post
Is there a way to gather two sets of parameters in one Textbox via code? Get Lux/Temp from a multisensor instead of separate textboxes with
[lux][/][temp].
Is this question related to the Squeezebox plugin or HS3 in general? If related to the plugin could you provide more context of what you attempt to achieve? In general to combine device values you can create a virtual device and format / update its value string using events and scripts.
Old January 3rd, 2017, 07:31 AM
pcp pcp is offline
Super Seer
A software player should work. Ensure the firewall ports are open for the player to reach lms and of course that the lms server is running. Once you have the player connected to lms, you can setup/connect this plugin.
Old January 3rd, 2017, 08:15 AM
[lux][/][temp].
Not related, I thought I deleted it.
HTML code is On
Getting Started Austin2406 HAControl 1 June 17th, 2010 07:34 PM
what do I need to get started? cadillackid Insteon Plug-in (Mark Sandler) 1 February 9th, 2007 08:26 PM
Please help get me started? pkoslow HS2 / HSPRO 9 September 27th, 2005 12:14 AM
How to get started with UPB picta HomeSeer UPB Plug-In (Beta) 7 September 26th, 2005 12:47 PM
How to get started in XAP cadillackid xAP Discussions 14 July 10th, 2005 08:34 PM
