Old February 10th, 2017, 12:21 AM
marco500 marco500 is offline
Seer Plus
Multiple LMS Servers? Possible?
Hello all,
I have purchased the PI and set up TWO LMS servers running on two Pi's. Configuring the first one was easy and works great, and I'm able to control/monitor it from HS through the PI.
However, when I went to create another instance of the PI so I can configure to the second LMS server, I ran into a wall.
How do I do this? I want multiple concurrent audio sources, both running LMS.
Please help,
Marco
Old February 10th, 2017, 12:41 AM
sparkman's Avatar
sparkman sparkman is offline
Hi Marco,
You can have many squeezebox clients from one LMS. I have 14 clients that can all play different music sources simultaneously or can be sync'd in different groups. Not quite sure I understand the use case for multiple servers.
Cheers
Al
Old February 10th, 2017, 11:46 AM
pcp pcp is offline
Super Seer
Originally Posted by marco500 View Post
Hello all,
Please help,
Marco
What is your use case to use multiple LMS servers? I have several clients connected to the same server, each playing different music (local, streaming radios, Pandora, etc) and some can be synced to play the same. This is first an "media/LMS architecture" question.
In you case, you would run LMS on one server (Linux, Windows, or one of the PIs) and then you one or more client players connecting to the server. The player can be logitech hardware players if you have them/find them (radio, boom, etc) or software players running on you PIs, Windows PCs, etc. For client software players you have a few options such as SqueezePlay, SoftSqueeze, squeezeLite, SqueezeSlave.
Old February 12th, 2017, 06:25 PM
Seer Plus
My bad!
Thanks for your feedback. I don't know why I didn't think of it in the right context (one server -> multiple clients). I needed two radio sources, so I was stuck thinking 2x servers.
Ok, I have two clients running against one server, and problem solved.
again, thank you.
HTML code is On
Support for multiple servers? mk1 black limited Blue Iris Plug-In 9 January 31st, 2017 04:53 PM
Multiple HS servers, common devices Wadenut xAP Discussions 18 October 12th, 2012 10:28 PM
Multiple servers or one MalcolmS Scotland 3 January 22nd, 2010 06:43 AM
multiple instances on multiple servers?? coffee_addict HomeSeer General Discussion Area 3 July 2nd, 2007 08:58 AM
