Old February 10th, 2017, 04:29 PM
Ramymounir Ramymounir is offline
Error
I dont know what is the problem but these messages keep appearing in the log
Feb-10 10:19:51 PM SqueezeBox Warning Synchronous Communication error upon connect: Connection refused.
Feb-10 10:19:50 PM SqueezeBox Warning Communication error upon connect: Connection refused.
Feb-10 10:19:47 PM SqueezeBox Warning Trying to reconnect to SqueezeBox Server
Old February 10th, 2017, 05:19 PM
pcp pcp is offline
Super Seer
Feb-10 10:19:51 PM SqueezeBox WarningSynchronous Communication error upon connect: Connection refused.
Feb-10 10:19:50 PM SqueezeBox WarningCommunication error upon connect: Connection refused.
Feb-10 10:19:47 PM SqueezeBox WarningTrying to reconnect to SqueezeBox Server
The plugin is attempting to connect to the lms server but the tcp/ip connections (2 of them) are refused. Check for firewalls blocking connection between the plugin and the LMS server (port 9090). Also try from the hs3 server to view the lms web pages using ie as a test.
Of course i assume you configured the LMS connection in the plugin configuration tab (LMS host especially).
Old February 11th, 2017, 08:28 AM
for some reason the LMs Cli port was 9091, i changed it to 9090, and it is working fine now..
HTML code is On
US Robotics modem error "Error in command AT+CPMS? : ERROR" jan.vanbezouw@gmail.com SMS Gateway (3P) 5 December 22nd, 2016 06:00 AM
Getting Error 8021 (Internal error retrieving device control block for the port) MasterMog WAF-AB8SS (3P) 6 September 16th, 2006 05:44 AM
8/15/2005 5:37:40 PM Error Error Sending email: 502 Error: command not implemented paul@thekaufs.com HS2 / HSPRO 0 August 15th, 2005 06:27 PM
HTTP Error 408: Server Timed Out Error With Sanyo 8100 PCS Phone? Rick Bonari WapSeer (3P) 10 July 9th, 2003 11:04 AM
