Old February 21st, 2017, 08:50 AM
Moskus's Avatar
Moskus Moskus is offline
The LMS spotify app + Spotify Protocol Handler -> No playlists!
I've recently had to wait really, really, REALLY long for my playlists in Spotify to show up on my Squeezeboxes using the old Triode plugin. I researched a bit, and found that I should now preferably use the Spotify Protocol Handler instead of Triodes original plugins (as it's no longer maintained).
Yes! Playlists loading time is practically non-existend any more!
BUT! Now the plugin can't find any playlists.
I'm trying to schedule a playlist in an event, no playlists show up. See the attached log and pictures.
I select player, then spotify and nothing shows up.
HSPro 3.0.0.368, Z-NET with Z-wave plugin 3.0.1.136, RFXCOM + 2x RFXtrx433E, HSTouch, Squeezebox plugin, iTach IP/WF2IR & GC-100-6 with UltraGCIR, BLDenon, NetcamStudio, Jon00s Webpage builder, Harmony Hub plugin, SCSIP (with FreePBX), Arduino plugin, IFTTT, Pushalot plugin, Device History plugin.
Are you Norwegian (or Scandinavian) and getting started with HomSeer? Read the "HomeSeer School"!
Old February 22nd, 2017, 08:56 AM
pcp pcp is offline
Super Seer
Z-Troller
Let me install the protocol handler and check this out. It will take me a few days to look into this.
Old February 22nd, 2017, 10:16 AM
Moskus's Avatar
Great!
I've always loved Triode's plugin, but I have to say that the Protocol Handler works great and much faster than the old discontinued plugin.
Old February 25th, 2017, 07:43 PM
pcp pcp is offline
Super Seer
If you open the Plugin player page, select Spotify (top left combobox), do you see any entries in the library list box below?
I installed the protocol handler and I see below in the player page. This web page uses the media APIs and same internal APIs to retrieve the library. I have not checked HSTouch yet; trying this a first step.
Old February 27th, 2017, 03:45 AM
Moskus's Avatar
Yes I see what you see.
But the Spotify playlist option is blank in the Events. And I have a hard time just "selecting" a playlist using the Play element option.
... but that's good news. Right?
I've also tried the "Play Library Entry" for the event, but half of the times, it just times out and the other half I'm not actually able to select the playlist, because the UI just opens the playlist and then track if I click on it.
Old February 27th, 2017, 10:10 AM
pcp pcp is offline
Super Seer
Thanks and wanted to ensure we have the results from the top level. The navigation to details is a bit different and I am making changes to the plugin to support the navigation starting with the plugin player web page. Going well so far and should improve navigation for other apps & radio (not original Triode Spotify or pandora LMS plugins).
The issue with HSTouch will be (as before) that the navigation depth is much greater that three and each navigation to details might include a mixture of folders (not a media), playlists, or media entries (can play it) but can still navigate to details (see LMS navigation in Spotify for examples). We discussed (with HST) requests and made proposals to support arbitrary tree navigation either in the HS3 music API or as a generic dynamically changing listbox style device status/graphics pairs, but never materialized. Gave up over the years; we will see what I can (maybe) come up this time, but bet will be a unfortunate compromise.
Old March 1st, 2017, 08:46 AM
Moskus's Avatar
I'm not that worried about HStouch, but I can understand if you are.
I just want to play a Spotify playlist.
Old March 1st, 2017, 08:10 PM
pcp pcp is offline
Super Seer
Thanks and that helps. I have the navigation in the player web page working much better. I need to make similar updates for the media browsing for event setup + more testing before releasing.
Old March 2nd, 2017, 03:59 AM
Moskus's Avatar
Great!
If you need anything, please let me know.
Old March 14th, 2017, 11:43 PM
pcp pcp is offline
Super Seer
Try version 3.1.4.12 in the updater. I added support for the Spotify protocol handler in the media selection in actions and the plugin player page. You should be able to select paylists (action to play playlists) or other Spotify entries (action to play an action by browsing the Spotify media library).
Old March 15th, 2017, 04:16 AM
Moskus's Avatar
Hmmm... I installed the new version and now the plugin refuses to connect to LMS.
Trying a restart now.
EDIT: Restart solved the problem.
Everything seems to be working great. All Spotify playlists show up and are playable.
Old March 15th, 2017, 07:25 AM
pcp pcp is offline
Super Seer
Great. For clarification, did you have to restart the plugin or HS3? I typically disable/stop a plugin before updating any. Ran into issues with HS3's update wrokflow otherwise.
Old March 15th, 2017, 09:24 AM
Moskus's Avatar
I didn't disable the plugin before update, I guess that was my big mistake. But when that mistake was done, I had to restart HS3.
Oh well, all is good now. I actually feel the plugin is using less CPU load than before (not that it ever was high!). Or is it just me?
HTML code is On
Spotify? lodi HomeSeer General Discussion Area 9 January 19th, 2017 03:39 PM
Spotify with HS3 Steve Q HomeSeer General Discussion Area 32 February 5th, 2016 06:12 PM
Spotify jgtec HomeSeer Software 6 December 14th, 2015 11:51 PM
Spotify and Homeseer Steve Q HS2 / HSPRO 4 January 15th, 2013 09:13 AM
Spotify posts PI-SonosController (3P) 5 March 18th, 2011 11:49 PM
