Wim,
Yes, I did upgrade deCONZ and the firmware.
The sensor name changes still do not stick. Light name changes work fine.
I deleted a couple of the sensors and let deCONZ find them again. That did not help the name change. I did end up with a sensor that deCONZ could not properly discover. It would only find the light sensing capability and not motion or temperature. I repeatedly reset the sensor (held the button in until the solid green came on) and did a scan sensor from JowiHue. After several attempts, deCONZ discovered it properly and all is well.
I ordered an Osram Sylvania Lightify (choose the name of the day) bulb to test with, should be here Saturday.
I also realized that my WiFi may have been interfering with Zigbee. Something for everyone to consider. I chose Zigbee channel 25 and moved all my WiFi to channels below 11 (actually to 1 and 6). That made a big positive difference in the number of green lines on the map.
Bill
Bill
