Thinking of replacing some of my 3way GE dimmer setups with Homeseer dimmers. Can someone tell me if it's a pretty straightforward wire swap?
Replacing GE dimmers with Homeseer
Originally posted by Rupp View PostAs long as your lights have the white common wire then the wiring is the same.
1. does it use the red traveler wire
2. I supposed I can't use the GE companion switches ?
3. Anyone know how I can get it in a dark brown?
oh... one more. assume double/triple tap work with companion switches as well? same events through all 3-way, or can it be different?
Yes, optionally if you need a companion switch.
I don't know on this one, I have only used the HomeSeer companion switches. But I think they are pretty simple devices so there may be a good chance of interoperability.
Not sure.
The companion switches simply mirror the double/triple tap event from the parent switch. They do not provide distinct/unique double/triple tap events.
Originally posted by savageautomate View Post1. does it use the red traveler wire
Not sure.
oh... one more. assume double/triple tap work with companion switches as well? same events through all 3-way, or can it be different?HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by rprade View PostThe Jasco companion switches will work with the HomeSeer dimmers and switches. They present a simple resistive value between the neutral and traveler wire. The HS and GE/Jasco companions measure the same. I am still using a few Jasco companions with HS switches.
Originally posted by Tomgru View PostOh man..... Wonder if HS will let me send back the $100 in companion switches I just received?
Sent from my KFDOWI using Tapatalk
