I'm getting a problem every time I try to control an X-10 device using the CM-15A plugin, this error pops up in the log whenever the event that attempts to turn the light on or off happens:
Nov-29 12:03:57 CM15A Error executing action: Conversion from string "" to type 'Integer' is not valid.
Of course the light I'm attempting to switch doesn't work. It used to work, is this a bug or a permanent limitation?
