Do you have local logins enabled?
Jon00 Homeseer Plugin Enable/Disable utility
v2 works great here just tested it.Preferred -> Jon's Plugins, Pushover, Phlocation, Easy-trigger,
HS3Pro 4.1.14.0 on windows 10 enterprise X64 on hp quadcore laptop 8 GB.
Jon;
When HST made the HSTouch plug-in part of the core program they reformatted the plug-in management page. They put HSTouch (Built-In) at the top. As a result the top plug-in (Arduino here) becomes an amalgam of HSTouch and the top plug-in in your devices. The devices cannot enable or disable the top plug-in. Other than the top plug-in the rest seem to work fine. I'm on my iPad right now, so I will add some screenshots later.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by jon00 View PostOK.
Please make sure you are using the release version of the utility. I believe you are still using the pre-release version I sent you when testing.HS4 Pro, 4.2.19.0 Windows 10 pro, Supermicro LP Xeon
Originally posted by jon00 View PostMust be something wrong at your end. I've had several guests in the last few hours and both my signature and URL posted work fine here.
The newly downloaded version2 stopped the Arduino plug-in from being mixed with HSTouch, above it on the list, but it is not there at all now.
Originally posted by jon00 View PostV1.0.2 is now available. This corrects the bug introduced when HST integrated the HSTouch plug-in as part of the core program.
what am I missing?My home is smarter than your honor roll student.
Originally posted by jon00 View PostIt is there! You can find it under 'all' or 'updated' or 'utility related' or the drop down at the top of the page. Look for: 'Jon00 Plugin Enable/Disable utility for Homeseer 3 (Version 1 and 2)'
Dude thanks for the excellent utility! without you, I would not be able to make the modbus plugin work and connect correctly with my midnite solar charge controller.
Guest
Hi Jon
I've just upgraded to Version 2 (V1.0.3). I am on the latest HS3 beta, 377.
Have followed the instruction manual. The script loads OK and creates 2 virtual devices as expected. But the plugins do not appear in the dropdown list. See attached screen grab. I have 12 plugins.
Any idea?
