I am having a lot of problems with the sms gateway or the usb modem. I have a dedicated Win 10 Pro x64 machine running HS3. I am using a cheap USB modem with a sim card for 3G, the modem has installed on Windows as a commcast device. It sometimes works for days without problem, but then I can see in the device SMS gateway root - disconnected. Trying to get it to reconnect is a real struggle. I disable the plugin, re enable it, restart HS3 etc . This time its not reconnecting again at all, I will probably have to restart the HS3 machine (which I cannot do right now as I am at work) to see if that works. In the log I have these errors:
Aug-09 08:11:39 SMS-Gateway Warning I've given up all hope of talking to the modem. I'm going to wait until you go to the config page and intervene or restart the plugin
Aug-09 08:11:29 SMS-Gateway Error Error connecting to COM6 : The requested resource is in use.
Aug-09 08:11:29 SMS-Gateway Error Gateway has been disconnected. Terminating.
Aug-09 08:11:29 SMS-Gateway Warning No connection to the modem, trying 1 more time(s) to connect.
Aug-09 08:11:19 SMS-Gateway Error Error connecting to COM6 : The requested resource is in use.
Aug-09 08:11:19 SMS-Gateway Error Gateway has been disconnected. Terminating.
Aug-09 08:11:19 SMS-Gateway Warning No connection to the modem, trying 2 more time(s) to connect.
Aug-09 08:11:09 SMS-Gateway Error Error connecting to COM6 : The requested resource is in use.
Aug-09 08:11:09 SMS-Gateway Error Gateway has been disconnected. Terminating.
Aug-09 08:11:09 SMS-Gateway Warning No connection to the modem, trying 3 more time(s) to connect.
Aug-09 08:10:59 SMS-Gateway Error Error connecting to COM6 : The requested resource is in use.
Aug-09 08:10:59 SMS-Gateway Error Gateway has been disconnected. Terminating.
Aug-09 08:10:59 SMS-Gateway Warning No connection to the modem, trying 4 more time(s) to connect.
Aug-09 08:10:11 SMS-Gateway Inbound message notification set to auto-notification by modem
Aug-09 08:10:10 SMS-Gateway Retrieved SMSC () from modem, storing in INI file for future reference
Aug-09 08:10:09 SMS-Gateway Connected to SMS Gateway
Aug-09 08:10:00 Plug-In Finished initializing plug-in SMS-Gateway
Aug-09 08:10:00 SMS-Gateway Initialising SMS-Gateway v3.3.4.18307 on COM6
Aug-09 08:09:59 Info Plugin SMS-Gateway has connected. IP:127.0.0.1:56145
Any ideas of what could cause this or how to resolve that problem ?
