I wrote this simple script as I wanted to use my PalmPad to control multiple devices across different house codes, I also didn't want to create a single new event for each.
Steps:
<UL TYPE=SQUARE>
<LI>Set your PalmPad to an unused house code. (Overlaps will transmit the same command over and start a loop condition)
<LI>Create a single new event that will trigger on any X10 command from the PalmPads house code. Set it to run this PalmPad.txt script.
<LI>Edit the PalmPad.txt script:
<LI> Edit this line to your new PalmPad house code: (Mine is P)
Const PalmX10 = "P1,P2,P3,P4,P5,P6,P7,P8,P9,P10,P11,P12,P13,P14,P15,P16"
<LI> Replace the devices you want controlled on this line:
Const NewX10 = "L16,L1,L9,L15,L10,L3,L11,L13,L8,A1,B2,M16,P17,P17,K2,K1 "[/list]
Each command received from the first Const statement will be replaced by the corresponding command in the send and resent.
I just needed something simple and quick, didn't want to create a ton of new events and so far this has been working great for me. I hope it will help someone else.
Currently this only sends X10 commands, but with a couple simple modifications you could have it hs.setdevicestatus or TriggerEvents directly without X10.
Discussion Here
Scott
[This message was edited by sbessel on Sat, 10 January 2004 at 01:36 PM.]
Steps:
<UL TYPE=SQUARE>
Discussion Here
Scott
